Boost referenced Regulator and pump Voltage ?
Old Apr 14, 2026 | 03:25 PM
30th t/a's Avatar
Default Boost referenced Regulator and pump Voltage ?
Hello,
Problem is Im not seeing 1:1 with fuel pressure and my brand new Aeromotive regulator.
QUESTION: Is 12.8 volts while in boost WOT good or no? Thats the voltage to the pump.
Cruising, voltage is 13.2 voltage then drops to 12.8 while WOT.
Old Apr 14, 2026 | 04:21 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Hard to say without knowing what pump.
Old Apr 14, 2026 | 04:52 PM
30th t/a's Avatar
Walbro 535 as the primary then the Walbro 450 comes on at 2 psi.
Old Apr 14, 2026 | 06:31 PM
gametech's Avatar
According to flow charts, that difference in voltage (if that is really what the pump is getting) should make very little difference. Are you sure the secondary pump is actually turning on?
Old Apr 14, 2026 | 07:12 PM
30th t/a's Avatar
Heres what i know for sure.
At Idle, When I jumper the hobb switch wires together,
the fuel pressure goes from 50psi to 65+psi, and I can hear the 450 running. I pull the vacuum line off and reset my base pressure.​​
I did a WOT pull with the switch wires jumpered and fuel pressure was worse! It wouldn't even break 60psi.
With the wires jumpered together I checked power at the 450 pump at idle and it showed 13.5 volts
I have not checked power at the 450 pump during a wot pull.
Also, duty cycle using the hobb switch = 99%
fuel pressure using hobb switch = 64psi
Duty cycle with both pumps on all the time 82%
fuel pressure with both pumps on = 58-59psi
Old Apr 15, 2026 | 07:29 AM
Old Buzzard's Avatar
How is the system plumbed?
Old Apr 15, 2026 | 03:51 PM
30th t/a's Avatar
Here you go.
New aeromotive 13139 regulator and vacuum block
LS3  fuel rails, FIC 1200cc injectors
Ls3 fuel rails with two -8 fittings welded on
Walbro 535/450 into a -8 Y fitting
Modified fuel bucket. No socks for test run.
-8 feed fitting
-8 feed fitting
-8 feed line and inline fuel filter
OEM fuel filter removed and fuel hose and fittings in place
T block with OEM return port capped off
LS3 fuel rails with two -8an fittings welded on
Old Apr 15, 2026 | 03:52 PM
30th t/a's Avatar
Here you go.
-8 feed fitting
-8 feed fitting
Old Apr 15, 2026 | 04:38 PM
A couple questions, comments.
1. Have you pressure tested those hard plastic feed lines to see if they leak at elevated pressure? If not, that's where I would start.
The basis for the ?: "I did a WOT pull with the switch wires jumpered and fuel pressure was worse! It wouldn't even break 60psi."
2. Pumps of that capacity and a return line designed for a system 1/4 of that flow, is a restriction at the rail & is a "pinch point" that could cause fuel heating.
How is the tank vented?
Old Apr 15, 2026 | 07:12 PM
30th t/a's Avatar
I have not pressure tested the fuel lines coming off the pumps.
I jumpered the hobb switch wires to see if maybe the switch wasnt activating the 450 to come on.
If im understanding the return line correctly, if it was too small, I would have too much pressure. I had no problem getting my base fuel pressure set to 58psi.
I went with -6 combined with using the OEM feed based off of other people's experiences and having no issues.
As far as the tank being vented, honestly never looked into it. I do believe all the evap stuff has been removed by the previous owner. The evap line is still in place but it's just an open line in the engine bay.
Old Yesterday | 07:01 AM
My goto is the pump/line pressure test. That's first.
Don't think I'd use gas as the fluid, due to a fire hazard.
I use a "Stoddard solvent" type flow fluid in the inj bench.
As for the return, it may be allowing enough flow but can cause excessive heat.
Check the vent.
Old Yesterday | 12:48 PM
30th t/a's Avatar
Check the vent.
Okay I will try this. Thank you for the advice.
Old Yesterday | 02:06 PM
Full Power's Avatar
Is that 1/8" white nylon FUEL PRESSURE line going through the firewall, into the cab ?
If that IS a fuel pressure line in the cabin, I strongly recommend it's immediate removal.
Old Yesterday | 04:15 PM
gametech's Avatar
Look closer. That is a vacuum line off a vacuum distribution block.
Old Yesterday | 06:23 PM
30th t/a's Avatar
Thats for the boost gauge
Old Yesterday | 06:56 PM
Full Power's Avatar
. Boost Ref port, Got it.
Thanks for reply: I feel better! haha
