Degree Wheel or Dot to Dot?
Old Apr 22, 2026 | 05:00 PM
Lght Spd's Avatar
Default Degree Wheel or Dot to Dot?
About to tear my C6 down to do heads and cam. I want to do this right and don't want any issues in the future if I can help it. The guy helping me is blowing off the degree wheel and says, "I do all the LS cam swaps dot to dot, and I've never had a problem."
I've watched videos on YouTube and even on Brian Tooleys channel, and they do the degree wheel.
Trick flow is telling me I need to do piston-to-valve clearance with their heads. So, isn't it in my best interest to do the degree wheel?
Old Apr 22, 2026 | 08:23 PM
Bob570's Avatar
I've never used a degree wheel on any of the cam swaps I've done. Every cam I've ever bought has been meant to run dot to dot. I guess it all depends how particular you want to get, but deciding to advance or retard it a couple degrees isn't going to make a difference that you can even feel. Unless every dyno comparison that I've ever seen is wrong.
You don't need one for piston to valve clearance, just get some valvetrain checker springs and some modeling clay to check for clearance.
Chances are that you're not running a big enough cam to even have to worry about piston to valve clearance anyway. Is this an LS7? Just guessing based off the picture in your signature.
I ran a 238/254 114+4 cam with 12:1 compression one a stock bottom end and I had plenty of room. I later upsized to a 245/256 112+4 camshaft with the same compression ratio and still had plenty of room, although that was with forged pistons. A lot of people are running a bigger cams than I am with stock pistons and 12:1+ compression with ported factory LS7 heads.
Old Yesterday | 06:32 AM
Kubs's Avatar
The degree wheel can be useful to know that the cam was ground similar to what the cam card says. If its off you can advance or retard based on what you measure, but more often than not the cams come out within a degree of what they should be anyway. Its nice information to know, but dot to dot will results will be the same.
Old Yesterday | 08:01 AM
Scott Danforth's Avatar
since you have to check PTV, may as well use the degree wheel to get it done right.
Old Yesterday | 09:14 AM
RB04Av's Avatar
All you're accomplishing using a degree wheel in a cam swap is, you're doing the cam mfr's quality control for them.
Don't bother. Dot to dot is fine, as long as you trust the cam mfr. Like most people who would ask this sort of question on an Internet forum, as opposed to experienced professionals, the indications from a degree wheel would be more confusing than they would be useful.
PTV clearance measurement needs will depend on the cam more than anything else. "Max lift" type specs are USELESS for predicting it, because the pistons come closest to the valves near the instance of TDC opposite the firing one, while "max lift" occurs when the piston is about halfway down the bore. Big durations, which will have the valves open significantly when the piston is up near TDC and the valves are "changing over" (exh closing and int opening), are what causes problems. A cam generally has to be pretty "big" before it causes problems with that, and particularly, "big" duration, although lift and duration generally go more or less hand-in-hand in the matter of "big"ness.
Note also that "dot to dot" is #6 firing, not #1. #1 is on the other instance of TDC at that time. "Both dots 12:00" is #1 firing; i.e. exactly 1 full crank revolution from "dot to dot". However, we build em "dot to dot" because it's easier to see accurately.
Old Yesterday | 01:08 PM
Lght Spd's Avatar
LS2 with a Comp Cam. Adv Dur: 281/289 Dur @ .50: 231/239 Lobe Sep: 114. Lift: 617/623
Trick Flow Heads. 225 cc Runner / 62cc Chamber. Inconel Exhaust Valves. (Boosted Application)
Cometic Gasket, 4.040" x .066" thickness.
Also, have the new PRW Shaft Mounted Rockers.
BTR .660" Springs.
BTR Titainium Retainers.
Old Yesterday | 01:45 PM
RB04Av's Avatar
Not a horribly "big" cam then. Seriously unlikely to be a problem. However, you can "solidify" a pair of lifters by filling w TransGel or Vaseline, slather some modeling clay on the head of a piston, bolt on a head w some sort of shim the same thickness as a gasket, install the prepared lifters w correctly chosen length push rods (VERY important if you don't want to end up in GIGO), turn the crank 5 or 10 full turns, pop the head back off, and see how thick the clay is at its thinnest, if you want. No check springs or other "special" prep needed besides the lifters.
Old Yesterday | 04:42 PM
Lght Spd's Avatar
Thank You for the insight.
Old Yesterday | 05:48 PM
dixiebandit69's Avatar
Unless you have an adjustable timing set, you will ONLY be able to install it "dot to dot", regardless of what the degree wheel says.
Old Yesterday | 06:25 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
And this is the actual answer, lol.
Old Yesterday | 09:23 PM
wannafbody's Avatar
Can't you pull the cam out and advance it or retard it and remeasure until you get it where you want?
