What sauce is everyone using on their factory T56
1) My 6 Puck **** the bed, so in goes a Monster S Twin. Should I use a Pilot Bearing (supplied by Monster) or a Orlite Pilot Bushing?
2) I was going to do new fluid while I was at it, so I'm trying to get an idea on what to use. The Bird is a 98, but it had an A4 to T56 swap, so other than the obvious, I'm not sure if it's a 98 or a 99+, so I don't know if it has paper or carbon synchros; is there a way to tell?
What would you guys suggest?
Dex III
Royal Purple SynchroMax
Schaeffer's 204SAT
Amsoil SYNTH ATF
Pennzoil Syncromesh
Tremec 75W85
Redline D4
For all T56 guys at Tick recommend:
Three quarts of Schaffers All Trans Supreme ATF ( )
One quart Schaeffer's Supreme Gear 75w-90 ( )
Three quarts of Schaffers All Trans Supreme ATF (https://www.amazon.com/dp/B00NJPSDYS...sin_title&th=1)
One quart Schaeffer's Supreme Gear 75w-90 (https://www.amazon.com/dp/B00MRZFYEI...fed_asin_title)
The only reason I can hear my radio ove my exhaust, is because it's over 4000W, so between the two, I doubt I'd hear the bearing 🤣
Is that for paper or carbon synchros? I need to figure what year my T56 is, so I know what kind of synchros I have.
Thanks for the info, man 👍
Why do you mix the two? I thought that the synthetic destroys the paper synchros.
On my most recent build I switched to bronze oilite after doing some research and found instances where shaft damage occurred with roller bearing failure. If you choose to go the bushing route make sure it is non magnetic.
