2002 WS6 Rebuild - Window Wiring
Hopefully someone out there can assist as I'm using AI and it's kinda making sense but I do not want to go just off that. I had stripped the interior to get metal fab and rust correction performed. That is now completed and I'm currently putting the interior back together. For the past two days I've been stuck on the door panels as they are structurally a mess from the prior owner. This all began because I needed to replace the window buttons as they broke the bracket and it needed new door speakers. I bought replacement Power Switch package from Hawks motorsports to just replace the entire housing for the door panel buttons.
Prior to install the buttons on the driver side door would raise and lower both driver/passenger windows. With the new buttons from Hawks, the driver side goes down but does not go up and the passenger side no longer goes up and down even though it did 2 days ago. On the passenger side the old and new buttons do not work. The driver side mirror and locks work w/both old and new. The passenger door locks work old and new.
Upon further investigation I noticed that the wiring harnesses both driver/passenger and both locks/windows appear to have been hacked up by the prior owner. All the wiring harnesses are wrapped in electrical tape which, according to AI, I'm sure isn't what it was from factory. Can anyone here validate if it should be like this or a suitable replacement? AI is pointing me to ACDelco or Dorman products such as the AC PT546 Driver Side Window Switch Connector and Dorman Door Window Switch Connector 645-942. Image below of the passenger side after I unwrapped the harness for the window buttons for reference.
FWIW, the factory assembly line did, in fact, use electrical tape in many places of the body and engine wiring harness (including in the door).
To your other point, that's exactly why I'm coming here instead of AI. Everything I'm questioning is from AI. For example, the bit about the electrical tape was very helpful. According to AI, that shouldn't be there that the factory never used electrical tape and that there should be a plastic housing it sits which is why it told me to buy those new wiring harnesses.
There are several places where the factory used plastic wire loom to better protect the harness, but AI is totally incorrect if it thinks that electrical tape wasn't used anywhere. I bought two of my LS1 F-bodies brand new and I can tell you that there was plenty of electrical tape used on the assembly line (sometimes to hold the wire loom, and sometimes instead of wire loom).
