4L80E Vs. Built4l60e Vs. TH400 ??
Old Oct 4, 2004 | 10:04 PM
LS1FIRE's Avatar
Default 4L80E Vs. Built4l60e Vs. TH400 ??
Hello Everyone. I am curious on which transmisson is better to run after the stocker goes out.
What are the advantages and disandvantages for these transmisson in a comparison?
What type of tuning and mods are required for fitment on a f-body when doing a th-400 swap our a 4l80e?
Which one of these transmissons will be more bang for the buck. Which one will be easier to obtain?
Which one will be better for street and drag strip use?
I plan on doing a H/C setup soon and I am already planning ahead just incase if my tranny died.
Old Oct 5, 2004 | 12:24 AM
James B.'s Avatar
This has been discussed, here's my opinion:
https://ls1tech.com/forums/showthrea...=212182&page=2
...and here:
https://ls1tech.com/forums/automatic-transmission/189467-why-th400-better-than-4l60e.html
In short, the 4L80-E is an unmatched 4-Speed Auto in well-mannered power handling.
Old Oct 5, 2004 | 12:36 AM
LS1FIRE's Avatar
Will the same convertor on the 4l60e fit the 4l80e?
Old Oct 5, 2004 | 01:16 AM
James B.'s Avatar
No, the 4L80-E has a larger input shaft and pump drive hub. The pump drive is ground flat on two sides to interface with the pump gear instead of notched linke the 60.
Old Oct 5, 2004 | 01:44 AM
LS1FIRE's Avatar
...and here:
https://ls1tech.com/forums/showthread.php?t=189467
so what about 4l80s on f bodies . Mostly found info about 4l80s and trucks.
Old Oct 5, 2004 | 04:08 AM
LS1FIRE's Avatar
Ive been doing some searches and found very little info on running the 4l80es on the f-body.
Old Oct 5, 2004 | 07:25 AM
WILWAXU's Avatar
Send a private message to burbanman
He has a 4L80 and loves it.
Old Oct 5, 2004 | 09:03 AM
GrannySShifting's Avatar
T400 wll hold anything built right for sure. A good bit lighter then the 80E and less parasitic drag. Choice of first gear ratios etc. Fully customizeable race trans
4L80E is at least close to the 400 in strength, but no transbrake. It can be worked with the stock PCM, and a fbody or truck can shift it electronically, and retain lockup. Good bit heavier.
 Michael S. Palmer
Old Oct 9, 2004 | 09:16 AM
MakoLS1's Avatar
th400s are stronger then the others will ever be, and lighter. I laid my 400 next to a 4l60e and picked them both up and the th400 feels alot lighter. I need to put them both on a scale and see what the weight saveing on my car will be.
Old Oct 10, 2004 | 12:33 PM
BigPlanTransAm's Avatar
ithere was a recent thread with a guy saying his 4L80e was only 40lb heavier than a 4L60e. its not that much heavier and for a street car, its worth it for the overdrive alone without paying 2,500 for a GV od.
Old Oct 11, 2004 | 12:01 AM
One Bad Z's Avatar
TCI said to put a 4L80E in an fbody it requires major floorpan modification and the torque arm brackets must be fabricated. What are they considering "major" modification?
I need a new tranny, mine went out last week. Havent decided to rebuild mine or buy a built race tranny. It needs to have OD though. I know guys that bought the $2000 Max Evil 4L60E and it has already went out on them (rated to hold 600+ horsepower and these guys were only pushing 500). I know guys that had their 4L60E rebuilt and they never had anymore problems with it. Some guys had theirs rebuilt and it has went out already also. What to do what to do?
Old Oct 11, 2004 | 08:57 AM
Kenafin_02TA's Avatar
My coworker has the 4l80 in his fbody...I know he didn't modify the floorpan. Don't know about torque arm brackets. The biggest problem he's had so far has been finding the right convertor for his setup (not in terms of fitment..but in terms of correct stall.)
Old Oct 11, 2004 | 11:00 AM
Kristin, tell CHad to give me a call about the converter
Old Oct 11, 2004 | 07:43 PM
GueSS Who's Avatar
I have had a TH400 for 8 months now and I love it. It is an unbeatable tranny
I now have a PG in the car and love it even more.
35th Anniversary SE SS.
408 CI
300 shot
9in
Old Oct 14, 2004 | 06:40 PM
Roadrunner 45's Avatar
no matter what you do, do NOT waste any more $$ on the 4L60E. TH400's are relatively cheap, can handle anything, and are an easy install. In the unlikely event it does crap out, you can replace it for a lot less $ than the electronic overdrives, converters are cheaper too. No OD is not that bad if you don't go crazy on the rear gear. Cars had no OD for years and years- we're just spoiled now...
Old Oct 15, 2004 | 10:37 PM
offaxis's Avatar
ITs actually about 80 lbs heavier than the 4l60
But hey if it doesnt break screw it Ill have to live with the weight
