BROKEN non EGR LS6 manifold FS $250 shipped takes it...needs map sensor
Old May 1, 2006 | 07:17 PM
hurley711's Avatar
Default BROKEN non EGR LS6 manifold FS $240 shipped takes it...needs map sensor
This is a LS6 manifold with the EGR blocked off, the map sensor in the back is broken. The brake booster line cracked and was causing a leak. It also had a slight crack on the drivers side in the back, but it was sealed up with glue and is holding fine, it wasn't cracked where it would cause a leak, just the back tip of the manifold was cracked a bit. I believe a new map sensor is $55from Fred Beans. The 2 pics are from when I first bought it, the map sensor is visible in the first pic and you can see the side which is broken. YOU WILL NEED TO REPLACE THE SENSOR IN THE BACK HOWEVER. That is shot and that is why I am selling it cheap. Paypal add $5
$240 shipped
Attached Thumbnails BROKEN non EGR LS6 manifold FS 0 shipped takes it...needs map sensor-ls6-001.jpg   BROKEN non EGR LS6 manifold FS 0 shipped takes it...needs map sensor-ls6-002.jpg
Last edited by hurley711; May 1, 2006 at 10:17 PM. Reason: price change and pics added
Old May 1, 2006 | 07:30 PM
hurley711's Avatar
Forgot to add, no plugs or crossover lines...just the manifold FS
Old May 1, 2006 | 08:41 PM
hurley711's Avatar
for the night
Old May 1, 2006 | 10:16 PM
hurley711's Avatar
Pics now added
Old May 2, 2006 | 01:00 AM
SSwanner's Avatar
PM sent, dibbs
Old May 2, 2006 | 07:41 AM
hurley711's Avatar
Potential buyer waiting for his response no $$$$ yet...morning crew bump
Old May 2, 2006 | 08:53 AM
SSwanner's Avatar
PM replied!
Old May 2, 2006 | 09:11 AM
hurley711's Avatar
Sale pending
Old May 2, 2006 | 10:13 AM
hurley711's Avatar
S-o-l-d
