Forged Boost 6.0L 364" /w 6.3" Rods & 402" Pistons, impressions?
I have a stock 3.622" crank, standard 6.0L block, 6.300" Eagle H-beam Rods, Mahle 4.00" (402" stroker shelf pistons) forged pistons...
This would be a standard 6.0" but have a longer rod and would probably work better for the high rpm boost motor project...
Any impressions of the long rod setup?
and will the stroker pistons work without the stroker crank?
I know regularpistons wont work with crank, wonder if you can do the other
if you use a piston setup for 6.125" rods on a 6.300" rod you are going to have many issues, main one is being way out of the hole at TDC
Since he is using a "stroker" piston, the pin height is going to be further up the piston...
As long as his extra length on the rod is matched with the pin height being higher on the piston...There is no way he is going to have the piston way out of the hole...
so IF you use a piston for a 6.125" rod on a 6.300" rod it would be way out of the hole.
actually his stated combo is way mismatched; 3.622 crank, 6.300" rods AND 4.00" 402 stroker shelf pistons(402 stroker shelf pistons are setup typically for a 4" stroke and a 6.098 or 6.125 rod), these parts as stated will not work together.
For all the math illiterates out there:
The formula for finding deck heigth is (stroke/2) + rod length + compression distance = 0 deck height. So let's plug in our numbers (3.622/2) + 6.300 + 1.125 = 9.236 inches. Nominal standard is deck is 9.240. On an uncut LS2 block mine was .008 in the hole before pistons were coated and the deck trued. Totally acceptable. Nominal deck heigth of an LS1 is 9.240
If anyone wants to know the part # for the piston it's a standard Diamond part # 11520. With the 15 cc dish , and 72 cc heads I can get anywhere from an 8.4 to to 8.75 compression ratio by very mildy adjusting deck heigth, gasket thickness or even chamber size.
Ok so it would totally work? I think im going to put this together with the long 6.300" rod, it should make a killer rpm turbo motor....
I'll remember that on the hellfire/stainless top ring...
Improving rod ratio, less side load, etc, all good benefits to running the longest rod within reason you can. I see no reason not to build a motor with a 6.300" rod when they cost the same as 6.125" rods...
