Trailblazer SS L92 head swap dyno
Old Jan 26, 2007 | 05:45 PM
Futral's Avatar
Default Trailblazer SS L92 head swap dyno
Just finished up an '06 Trailbalzer SS with a set of L92 heads.
Previous dyno: 221\224-115 cam only,stock heads
Current dyno: Bowl blended L92 w\stock valves and new cam
mods:
-Stainless works headers
-Single Magnaflow exhaust
-Cold air intake
-Yank 3600 converter
-ASP pulley
-L92 heads and intake setup
-custom cam 224\?-? nitrous cam !
-stock gears and rims\tires
UNLOCKED numbers,but not to bad for a 224\xxx cam to start with
NOTE The dyno graph starts out low due to having to roll into the throttle and full throttle about 4600 RPM
Old Jan 26, 2007 | 05:58 PM
Magnet's Avatar
Old Jan 26, 2007 | 06:20 PM
WizeAss's Avatar
mods:
-Cold air intake
-ASP pulley
-custom cam 224 ?
UNLOCKED numbers,but not to bad for a 224 cam to start with
looks like that cam/head combo is carryin way past 6500 rpm...... any figures you are willing to share on said cam? how big? how much duration? what have you found that does or doesnt work.
No benifit to you from me as someone else is doing my setup..... but I would appreciate any input you are willing to share...... thanks for sharing the results!!! that is Killer!!!!!!
Old Jan 26, 2007 | 07:38 PM
tmoneyr007's Avatar
Man I wish someone would show the before and after from 2K and up. I'm more interested in the loss/gain of power down low. Especially in a heavy TBSS or GTO.
Old Jan 26, 2007 | 07:45 PM
tlaselva's Avatar
Wow, that's excellent power. Strong torque curve right to redline, so it'll pull hard all the way through!
Old Jan 26, 2007 | 07:51 PM
LS1 Eddie's Avatar
Any videos or sound clips I would LOVE to hear it. Nice job!
Old Jan 26, 2007 | 08:22 PM
ThunderStruk's Avatar
The problem is we tried to start it lower, but it would kick down to 2nd gear everytime
Old Jan 26, 2007 | 08:32 PM
mr2guru's Avatar
What were you tuning it with? HPtuners you can lock the 'verter and gear on the fly.
Old Jan 26, 2007 | 08:37 PM
White_Hawk's Avatar
Awesome setup. I have resisted de-modding thus far, but for the money a setup like this could be do-able (on my lease truck!).
What about the tune? Custom I assume?
-Geoff
Old Jan 26, 2007 | 08:39 PM
GreenBlood's Avatar
wow, thats pretty sick...
Old Jan 26, 2007 | 09:23 PM
PEDRO's Avatar
12 Second SUV Club
great to see that i wonder what my h/c package will do on my tbss
Old Jan 26, 2007 | 10:29 PM
digitalsolo's Avatar
Great numbers; This bodes well for my 224/xxx L92/L76 370" motor. If I can get 450-475 RWHP out of it before spray, I'll be pleased as punch.
How's the low end and drivability on it? Should be good with the little cam I'd think?
Old Jan 26, 2007 | 10:32 PM
scalarrthu's Avatar
+1
I am probably getting ready to do a h/c kit on the SS and would like to have a better idea on which cam would work the best.
Also, how did the SW headers match up to the heads? Any problems?
Old Jan 26, 2007 | 11:30 PM
gator's 99TA's Avatar
great work allen
Old Jan 27, 2007 | 12:13 AM
TRW427SS's Avatar
We didn't get to pull it that low on the dyno but it pulls harder down low than it did with the stock heads!!! It has more power from the bottom to the top!
Old Jan 27, 2007 | 04:23 AM
1BDWS6's Avatar
If the engine wasn't broke in the Formy, I'd be all over this....
Old Jan 27, 2007 | 07:55 AM
tdrumm's Avatar
What intake manifold did you use for this setup? Please say L92 truck intake!
Old Jan 27, 2007 | 10:08 AM
Racin96ss's Avatar
Hey...what intake are you using?
Old Jan 27, 2007 | 10:58 AM
Futral's Avatar
L92 truck intake with the ported stock Trailblazer 90mm T\B.
I tuned it with HP tuners. Used my Tech 2 scan tool to lock the converter but the converter would let loose about half way through the pull but still showing it was controled locked.
Old Jan 27, 2007 | 11:24 AM
White_Hawk's Avatar
Also, are the heads milled? If those numbers include the drop in compression, then WOW!
-Geoff
