FOR SALE: Rossler Terminator 3 4L60E
Old Feb 3, 2007 | 05:58 PM
RomanK's Avatar
Default FOR SALE: Rossler Terminator 3 4L60E
Hey guys, im selling the Trans simply because i have no need for it. It does require a rebuild as 3rd and 4th are supposedly slipping as the previous owner tells me, i bought it about a year ago i guess, and never sent it off for rebuild or installed it, PM me if you wish more info on the original owner and background. Im asking $900 plus shipping, new one from ROSSLER would be about $2600+ and should hold over 600 rwhp, btw im located in south alabama, 36360 to be exact, here are the specs:
· Modify Lube Circuit
· Modify pump to HP specs.
· High RPM pump slide spring
· Modify input drum – prevents input drum breakage at spline area
· HP 3-4 9/clutch pack
· Install Ross/lock™ ¾ clutch kit 20% more surface area than normal HP 9 clutch kits
· HP reinforce mounting lugs 2ed gear
· Band 18% more holding power than normal HP type bands
· Modify for bearing kit-ring gear support hub, eliminates brass washer wear
· Heavy duty sun gear shell prevents breakage at spline (beastTM)
· Reprogram valve body Ross-Lock ™
· Corvette type 2ed gear Servo kit
· 4th gear billet servo kit
· 2ed Gen. Sprag kit
· 10 vain pump rotor
· Add Turbulator™ steels where applicable
Also has a deep pan with drain plug. The trans is black with a sliver belhousing and a silver tail shaft housing.
PM me for paypal
Old Feb 4, 2007 | 11:30 PM
RomanK's Avatar
to the top
Old Feb 5, 2007 | 06:20 PM
RomanK's Avatar
No questions or anything?
Old Feb 8, 2007 | 12:00 AM
RomanK's Avatar
back up top, PM's answered
Old Feb 9, 2007 | 12:57 PM
RomanK's Avatar
Still up for a good deal
Old Feb 9, 2007 | 02:23 PM
sks355's Avatar
If It Is For A Ls1 I Have Cash And Ready To Make A Deal.
Old Feb 9, 2007 | 11:12 PM
sks355's Avatar
deal is done
Old Feb 9, 2007 | 11:13 PM
RomanK's Avatar
sold!!
Old Feb 9, 2007 | 11:25 PM
sks355's Avatar
roman please clean out your Pms so i can message you on details
Old Feb 15, 2007 | 02:52 PM
sks355's Avatar
OK PAYED ON THE TRANSMISSION SAID HE WOULD BE SHIPPING ON MONDAY, I HAVENT HEARD ANYTHING AND NO REPONSE ON MY PMs....MY *** IS STARTING TO BLEED.
