FS: Valvetrain, SFC's, Battery Relocation, ABS Delete
Old Sep 12, 2007 | 06:48 AM
iamsickofitall's Avatar
Default FS: 317 Heads, FAST 90/90, Battery Relocation, and more
NIB UMI 1993 - 2002 GM F-Body Boxed Style Weld-In Subframe Connectors Part No. 2000 - $140 Shipped - SOLD
NIB Taylor Battery Relocator Kit (1 gauge cable) Part No. 48010 - $75 Shipped
NIB Taylor Master Disconnect Switch, 2 Post Part No. 1032 - $20 Shipped
Assembled 317 Heads with Rocker Arms (unknown miles...I was told approx. 30k) - coolant temp sensor not included - $300 Shipped
FAST 90/90 setup that I bought used with no apparent defects. The intake was lightly ported to get those nubs ground down on the runners and the hardware has some surface rust. I replaced the throttle body cam, butterfly, bearings and put in a stiffer return spring and the TB has never stuck on me. Buyer is responsible for getting the appropriate valley cover bolts since mine are not being removed from the car. - $850 shipped - I will get pics of this up in the next day or so (today is 3/25/2008).
NIB Patriot Performance Dual Gold Valve Springs - $230 Shipped - SOLD
NIB Crane Dual Valve Spring Compressor Tool - $115 Shipped - SOLD
2003 LS6 Cam (unknown miles) - $165 Shipped - SOLD
ARP LS1 Head Bolts (used) - $90 Shipped - SOLD
NIB LS6 Valley Cover - $65 Shipped - SOLD
Unused Siemens 60lb Injectors - $375 shipped
NIB Updated GM Slave Cylinder - $100 shipped - SOLD
A hacked up '00-02 throttle body that I was stupid enough to buy unseen. Don't know if it's salvageable or not - $30 shipped - SOLD
Used Holley Powershot Filter w/ NIB K&N Filter Oil - $20 shipped
NIB SJM ABS Delete/Line Lock Kit (4 channel) - Kit comes with proportioning valve, solenoid, double-flare tool kit, pre-formed lines, OEM brake line fittings, master switch with remote LED, control switch, fuse with holder, wire, electrical connectors and pictorial directions with schematics. - $190 Shipped - SOLD
Turbosmart Manual Boost Controller (used) - $55 Shipped
Shipping included to the 48 contiguous states only. Paypal is preferred. Thanks.
Old Sep 12, 2007 | 06:58 AM
Thorny's Avatar
YHPM on valley cover and head bolts
Old Sep 13, 2007 | 02:01 PM
new stuff added
Old Sep 13, 2007 | 02:18 PM
95GreenZ28's Avatar
I will give you 12 shipped on the coolant sensor in the head. Is it off a ls1?
Old Sep 13, 2007 | 04:46 PM
98turbls1's Avatar
May be interested in the Z06 cam... Anymore pics of it??
Old Sep 13, 2007 | 05:56 PM
Thorny's Avatar
Payment sent for head bolts. Thank you
Old Sep 13, 2007 | 09:35 PM
2001SS#3013's Avatar
Can you email me a picture of the throttle body? whitesscamaro@hotmail.com.
Thanks.
Old Sep 13, 2007 | 09:46 PM
Thanks.
i'll get you a picture as soon as i can find the USB cord for my camera...i think i left it at the office
Old Sep 14, 2007 | 07:27 AM
here are the TB pics...i'm too lazy to resize them (they're 7 megapixel and uncompressed) and email them so i just tossed them up on photobucket....and yes, that's my electric toothbrush in the background. i was trying to find good lighting because you can't see anything when i use the flash and the bathroom was the best i could find at the time. SOLD
Old Sep 17, 2007 | 01:16 PM
bumpage
Old Sep 21, 2007 | 05:46 AM
to the top
Old Sep 26, 2007 | 06:58 AM
up up and away
Old Sep 26, 2007 | 07:53 PM
NovaCain383's Avatar
Does the spring compressor work on all of the springs. I read that there is one that will do all but 2. Somwthing about it being to tight. I think on the passenger side. I will be using it while the engine is still in the car.
Thanks,
Criss
SBP
Old Sep 27, 2007 | 12:35 AM
Thanks,
Criss
SBP
the crane tool will work on all cylinders with standard tools while the heads are in the car. there is some minor material removal from the compressor tool that will need to be addressed if you have AFR or Dart heads tho.
Old Sep 27, 2007 | 09:44 PM
PM me bottom dollar shipped on the Valve Spring tool? Do you take Paypal?
Thanks,
SBP
Old Oct 1, 2007 | 08:50 PM
aw01m6t\a's Avatar
did you get my pm?
Old Mar 25, 2008 | 04:55 PM
bringing this one back from the dead
Old Mar 25, 2008 | 07:43 PM
SILVER SS 00's Avatar
do you still have the Taylor Master Disconnect Switch, 2 Post Part No. 1032,let me know
Old Mar 25, 2008 | 11:25 PM
CaMaRo67RS355's Avatar
you interested in seperating the cables for the batt relo kit? i already have my box...
Old Mar 26, 2008 | 05:36 PM
all pm's replied and all status of parts availability updated
camaro67rs355 - I would like to keep the relo kit intact...for now.
