Big parts list, T56 trans, Strange 12 bolt, LS1 Block, Miscellaneous parts...
Strange 12 bolt Rear end. 1350 Yoke, 33 spline axles, 3.42 gears, auburn posi, T/A girdle cover. No problems at all. It only has less than a thousand miles since it was fully rebuilt with new bearing and gears. It was only rebuilt because the pinion seal was leaking and it had a howl that would resonate throughout the car. New bearings, pinion seals and gears were all installed. SOLD
T56 Transmission with bellhousing, no problems, shifts like it should. SOLD.
Bare LS1 block, honed and cleaned. SOLD.
Pro 5.0 shifter. SOLD.
Front cover. $40.
Rear cover $40.
Valley cover. $40.
Oil pan. SOLD
Lifter trays. $20.
Ram powergrip clutch and pressure plate. $200.
Resurfaced factory steel flywheel. SOLD
Engine mounts. $30.
Wiring Harness with PCM with a cam only tune. SOLD
Rear rotors freshly resurfaced. $30 per rotor. One measures 25.1 and the other 25.3. Minimum thickness is 24.7/
Cam sensor. $15.
Crank sensor. $15.
New snapon 1/2" torque wrench. Make offer.
New blue point air ratchet with swevil sockets. Make offer.
New snapon Torque angle gauge. Make offer.
oh, and what are you looking to get for that snap on 1/2" torque wrench? is it the micrometer style or the other style with the wheel?
http://img.photobucket.com/albums/v4...f/DSC02415.jpg
http://img.photobucket.com/albums/v4...f/DSC02414.jpg
http://img.photobucket.com/albums/v4...f/DSC02413.jpg
