Lots of stuff for sale (rear, brakes, ls1 plates, etc)
Hurst quarter-stick shifter
Sold.
Stock 94 fbody rear with 4.10's
Sold.
Precision 'vigilante' torque converter
Came off my pop's LT1 car. Works with th400. Stalled around 3500 behind his car on motor (~400 rwhp).
Was $350 now $250
Tons of misc parts from 93-97 cars
Tan/grey interior stuff let me know what you need and I probably at least one of them. I bought a complete grey interior (w/ seats) and the 93 came with a nearly complete tan interior (minus seats). Have a few stock automatic shifters as well.
LS1 valley covers
Two of them. $15/each
4" turbo bells
Fit over my old twin t66 setup. Have two of them with the rubber coupling included as well as t-bolt clamps.
Complete KTS racing LS1 motorplate setup (front and mid)
Moser 9" for 82-02 Fbody
35 spline axles, 5/8 studs, 4.56 gear
Axels shortened by Moser 1.5"
Strange Case
Spool is Aluminum (So they said)
Daytona Pinion
Fill Added
LCA Relocation Brackets weld-on
Wolfe Single sway bar ($360 + welding to install it)
DTS put it together
Its only been used for rolling
Rear itself was $2400 and then $$$ for the additional work and it's not even been run yet.
Was $2600 now $2300
Stock LS1 rear brake setup with modified calipers (ground down) to clear 15" wheels
3.5" Aluminum LPE driveshaft
http://www.lingenfelter.com/store/ln0350s.html
Was $250 now $150
Summit Chrome th350/th400 dust covers
SUM-G3883 is the p/n.
I have two of them and they are both brand new.
Summit sells for $28 + ship. I'll take $15 + ship /each.
M/T 28x12.5 et streets
Not much life left but would be great for a few passes or for mock-up.
$40 for the set.
M/T 28x10.5 et drags
Emails to LTLHOMER@aol.com
I will be adding to this list often.
Sold.
Sold.
Was $350 now $250
LS1 valley covers
4" turbo bells
Strange Case
Daytona Pinion
Fill Added
DTS put it together
Was $2600 now $2300
Was $250 now $150
$40 for the set.
Do the valley covers have the knock sensors?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
No knock sensors.
The backing plates, bracket, used rotors, and calipers. What else do you need?
