tons of f-body parts FS in dfw
here is a list of everything i can think of, if there is anything else you need feel free to pm/e-mail me
stock 95 LT1 A4 tranny worked great when pulled-$200
94 LT1 a4 tranny with a shift kit and a 2800 rpm stall, less than 100 miles since install-$450
V6 273 complete rearend with drum bakes-$80 picked up
stock LCA's-$15 pair
LT1 A4 steel drive shaft-$30
stock torque arm-$20
LT1 formula front impact bar-$20
LT1 camaro front impact bar-$20
LT1 camaro headlight bar-$80
LT1 firebird/trans am headlight support bar-$50
LT1 110MPH gauge cluster w/125k miles-$25
dual horn assembly-$15
spare jack and lug wrench assembly-$20
LT1 heater hoses-$25
A4 LT1 tranny crossmember-$20
LT1 stock k-member-$30
LT1 motor mounts-$30 set
stock a-arms-$30 pair or $20 each
complete a-4 shifter assembly with cables-$40
97 V6 A4 tranny 95k miles worked great when pulled-$120
93-96 camaro dash-$80
93-96 camaro upper dash pad-$80 picked up only
93-96 camaro HVAC controls-$20
tan dome light-$10
gray dome light-$10
96-97 M6 LT1 motor/tranny wireing harness in great condition-$50
stock LT1 maf-$30
LT1 powersteering resivor-$20
96-97 airbag sensor-$20
94-95 airbag sensor set (all 3)-$25
t-top divider (mounts on roof)-$20
LT1 stock crank pully assembly-$20
LT1 underdrive pully-$20
96 LT1 stock cam-$20
96/97 stock timing cover-$50
LT1 brake booster-$20
LS1 brake booster-$20
96-02 V6 starter-$30
LT1 starter-$40
LT1 water pump less than 100 miles-$50
LT1 stock coil assmbly-$30
LT1 a/c lines form compressor-$25
10 bolt diff cover-$15
white firebird hood hinges-$20 set
LT1 brake master cyl assembly-$30
LT1 stock valve covers-$25
LT1 fuel sending unit-$40
firebird headlight control panel-$20
non-tcs LT1 throttle cable-$25
A4 pedal assembly with sensors-$40
M6 pedal assembly with sensors-$60
LT1 firebird complete passenger headlight assembly with motor in red (needs paint)-$80
stock LT1 rockers-$20 set with nuts
stock LT1 pushrods-$15 set
stock lifters-$30 set
stock cam timing gear-$20
stock timing chain-$20
t-top firebird a-pillars in gray-$30 pair
passenger tinted t-top-$120
LT1 steering rack-$40
LT1 steering coupler-$15
LT1 steering column with key-$75
firebird drivers airbag in gray-$40
Z-28 camaro hood (needs paint)-$25 picked up
tan seatbelts front and rear complete with hardwear-$40
drivers f-body door glass-$20 picked up
LT1 camaro drivers tail light-$25
complete 323 rear-$200
LT1 rear calipers-$40 pair
spare tire (looks new)-$20 picked up
hatch lock assembly-$15
complete 93-96 camaro steering column with airbag-$125
rear view mirror-$20
LT1 A4 radiator thick core (1.25 in instead of the 1in on the 96 and newer a4's)-$80
lt1 dual fan assembly-$80
V6 single fan assembly-$50
red firebird mirrors-$30 each
93-96 LT1 camaro 150mph gauge cluster 91 k miles-$40
i'm located in mansfield tx 76063
all prices are obo and without shipping
my paypal/e-mail is f-bodyparts@hotmail.com
thanks
robbie
tan dome light-$10
gray dome light-$10
stock LT1 maf-$30
LT1 starter-$40
thanks
robbie
