Improper Valve Seal Install Can Cause Catastrophic Failure PICS INSIDE!!
Old May 7, 2008 | 09:38 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Default Improper Valve Seal Install Can Cause Catastrophic Failure PICS INSIDE!!
Guys I think this is very important & needs to be in it's own thread.
When installing anyone's spring kit you need to make sure you install the proper seat/seal combo that is designed for your spring kit. We recently had a customer install double springs on a stock seat / seal assembly & this can cause a huge problem.
Basically the stock seat/seal assembly has a od of .890" where the spring located. The inner double springs that most companies on ls1tech offer uses a ID of .676". As a result if you install the double spring over the stock seat you'll cause the inner spring to be elevated approx. .180"
The inner spring is designed for a install height of approx. 1.800. This inner spring will coil bind at 1.100. If you space the inner spring .180" on top of the 1.800" install height you will be left with less than .520" of lift before coil bind!!
Figures:
-.180" step on stock seat
= 1.620" available install room
1.620-1.100" coil bind leaves you only .520" lift from coil bind, or approx. .470" lift safely.
From these figures it's easy to see even a stock camshaft could cause coil bind when double springs are installed with the stock seat!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 7, 2008 | 09:41 AM
Pic of PRC seat & stock seat with inner spring sitting on it:
__________________
Jason
2005 Twin Turbo C6
Old May 7, 2008 | 10:32 AM
rocksws6's Avatar
I just can't figure out why somebody would want to reuse the stock seat. Its not like it's that hard to pull the seat off if your taking the springs off and on anyway. Even the valve seals are really easy to change. Why would somebody do that?
Old May 7, 2008 | 10:40 AM
CABRO's Avatar
sorry for the noob question....... but where is the failure. i know from the pics that you are comparing the two. but am i not seeing something. is one of the springs busted.
Old May 7, 2008 | 11:02 AM
CABRO's Avatar
never mind just read the other thread. and holy cow did it go kaboom!
Old May 7, 2008 | 11:03 AM
__________________
Jason
2005 Twin Turbo C6
Old May 7, 2008 | 01:41 PM
brad8266's Avatar
I just see red x's
Old May 7, 2008 | 01:45 PM
Sales2@Texas-speed's Avatar
Brad, I just tried it on several PC's and it's showing them. Anyone else got X's??
Here are the links anyway:
http://www.precisionracecomponents.com/rocker5.jpg
http://www.precisionracecomponents.com/rocker6.jpg
http://www.precisionracecomponents.com/rocker7.jpg
http://www.precisionracecomponents.com/rocker4.jpg
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 7, 2008 | 02:02 PM
brad8266's Avatar
I saw the pics in the original thread that were posted by the OP.
Lesson learned I guess although i cant believe he just didnt replace the seals and seats in the first place, pretty dumb move.
Old May 7, 2008 | 02:13 PM
BlackSS2001's Avatar
I got pics. NO red X's here. although that last pic is blurry I want a good pic of the jacked up spring
Old May 7, 2008 | 02:21 PM
brad8266's Avatar
weird, i dont know whats going on here cause I still have red x's.
Old May 7, 2008 | 02:31 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I can see all the pictures and I then clicked on the other thread. I'm guessing there are plenty of people in that thread that are eating crow. That breakage is deffinitely a valvetrain geometry issue and if the inner spring went into coil bind, that would be enough to break an aluminum head over time especially with a high lift cam.
I chalk this up to another reason not to run a dual spring. I'd rather talk to PAC and get a higher pressure beehive to control harmonics and flutter.
Old May 7, 2008 | 03:32 PM
hellbents10's Avatar
LS1Tech Sponsor
I seen the other thread and I figured right away this is what happened. You have to replace the seats/seals for the dual's. No reason not to, other then time and a million reasons to do it.
Old May 7, 2008 | 04:36 PM
brad8266's Avatar
I can see them now from home, couldnt see them from work. Weird.
Old May 7, 2008 | 04:45 PM
dmart's Avatar
This was 100% installer error, it's not like seals/seats are hard or expensive to replace. Any spring is gonna cause huge problems if it binds, or is setup improperly, triple, dual, beehive, whatever.
Old May 7, 2008 | 05:52 PM
Fb0dy0nly's Avatar
Quick question, I just installed PRC dual springs with all the new hardware. When you put the new oil seals on and tap them in all the way, is the spring that goes around the top suppose to scrunch up a bit? I noticed this was happening when I was installing the new seals on the new seats. Thanks.
Old May 7, 2008 | 07:00 PM
Stangkilr's Avatar
Not everyone in all cases re-use them. Sometimes the heads show up brand new with brand new seats/seals already on them. W/O knowing this thinking you can just use that seal and seat a major failure can happen. Thank you for making this thread, hopefully it will save some people down the road. In fact this should be a sticky.
Old May 8, 2008 | 09:29 AM
I've never seen any double spring kits installed on a stock valve seal. I think if you do a little bit of measuring you'll find out there just isn't enough room between the stock seat assembly & the cylinder head material.
This is probably the second time I've ever heard of someone trying this in probably 5000+ spring kits all the vendors on ls1tech have sold.
I hardly think it's worthy of a sticky, but what do I know I got bashed by you guys for 3 pages over this...
__________________
Jason
2005 Twin Turbo C6
Old May 8, 2008 | 01:33 PM
venom ws7's Avatar
Good info thanks Jason.
Old May 8, 2008 | 02:26 PM
Zach@MTI's Avatar
I am ashamed to say that I read the other thread entirely...
Classic example of parts being installed incorrectly. TSP, you can't hold everyone's hand.
