budget lq9 build results
Old Aug 13, 2008 | 11:39 PM
92 silverado's Avatar
Default budget lq9 build results
2001 m6 z28
2002 escalade lq9
-bottom end-
arp rod bolts
clevite coated bearings
moly rings
ported oil pump
-top end-
stock 317 casting heads ported with a 3 angle valve job
dual gold valve springs
magic stick 3 cam advanced 4 degrees
rollmaster double roller timing chain
ls6 intake
bbk 80mm throttle body
comp hardened push rods
-other-
40# injectors
centerforce dual friction clutch
aluminum driveshaft
k and n fipk intake
85mm slp maf
pacesetter headers
off road y-pipe
magnaflow catback
tuned my ryan at rpm in garner, nc
410whp 397ftlbs
Old Aug 15, 2008 | 02:01 AM
AINT SKEERED's Avatar
is this a fresh motor? looks good but will get better with more break in time.
I have a lq4 with milled, ported ls1 heads but have not dynoed with this setup yet. It feels strong though.
Old Aug 17, 2008 | 12:12 PM
yup this motor had 2000 miles before the dyno
Old Aug 22, 2008 | 08:25 PM
cbra-klla's Avatar
thats good torque with the ms3
Old Aug 24, 2008 | 01:32 PM
formybird's Avatar
Good numbers. I also went the budget LQ9 route.
Here are my dyno results https://ls1tech.com/forums/showthrea...652&highlight=
Still have a few odds and ends to take care of so no track times yet.One day lol. Good luck with yours.
Old Aug 24, 2008 | 10:15 PM
badazz99ta's Avatar
nice number man. i am considering this route.
Old Aug 28, 2008 | 03:22 PM
Billiumss's Avatar
Those are low numbers, your about 20 HP low, you have more cubic inchs than a regular LS1.
Whats the CR, 9.2-1?
Old Sep 7, 2008 | 11:27 PM
20hp low? i dont have anything major really the compression ratio should be about 10:1
