Injector Resizing For LS1, 2, 3, 6, 7
http://www.youtube.com/watch?v=RgIx1OtYbZY
I would also like to publicly endorse this company and their ability to do outstanding work.
In addition to these injectors I also sent them a set of stock LS3 injectors and had them flowed to 60LBS/HR, not only were they professional I had the injectors back within 3 days from the day I dropped them off.
I installed them in a 2008 Corvette we did with a Pro Charger,Melrose Long Tubes,Random cats and X-Pipe,with a magnaflow Cat Back. I have to say this was the easiest car I have ever had to tune. I made 3 pulls and I was done !! The car drove like it was stock again.
If anyone needs any injectors cleaned or reflowed I strongly suggest you use the Fuel Injector Connection. Thanks again guys !!
:thumbsup::thumbsup::thumbsup::thumbsup:
Can I trust them to be resized to 42lb and last?
I am running a set of used lucas injectors and I think some of them are leaking or not running right.
That sounds pretty good
I can't tell from that pic, its tiny, I have a set of the 43's out in the shop right now I took out of my truck to put some 60's in. These are the specs on them.
Part Number 17113739 (OE Part # 25176061)
Direct fit for short G.M. LS1 SUV injectors
Static flow @ 37.95lb/hr @ 43.5PSI / 300KPa (4.31 g/s = 398cc/min)
Static flow @ 43.82lb/hr @ 58PSI / 400KPa (4.97 g/s = 460cc/min) *
Dynamic flow (2.0ms/10.0 ms(pulse width / rep rate)) 6.0 lb/hr @ 43.5PSI (0.748 g/s @ 300KPa)
Coil Resistance: High Impedance / High-Z (No ECM driver modifications required)
What do you want them flowed to?
Monello, sorry it took me a bit. Yeah, we can do those to 42 easily. I would recommend doing our cleaning and service as well as re flowing them. Were doing a special for our 11 point cleaning and refurbishing service as well as custom resizing for $30 per injector.
