82% duty cycle with 60s
tonight i did a WOT run in 3rd and noticed my duty cycle at 82%. i have motron 60s with 58psi with 0 vaccum. this was at 15psi of boost. fuel system is dual 255s -8 feed -6 return. does thsi sound reasonable? also is there any reference to HP that is being made with this much duty cycle on properly setup fuel system?
Ok. Is 600FWHP a close estimate of what U R making?
Some quiky calcs show that, at 600FW, BSFC @ .6, and a duty cycle you have reported, the injs should be operating in the 54.9#/hr area.
@ 58psi op pressure, the injs are now rated at 69.28#/hr. Your reported DC of 82% looks to have a flow of 56.8#/hr.
Looks really close to me....
bsfc of 0.6[6lbs of fuel /10 hp]average for forced induction motor.
82% of 72.3=59.286lbs of fuel used per injector
59.286/0.6=98.81 hp per injector
6cyl would be 593 hp
8cyl would be 790 hp
about- so I expect you are seeing that hp uncorrected if the tune is at 0.60 bsfc.
that is a good question...
FWIW, I'm at 49 psi on a set of 50lb'ers and they are rated at 43.5... So they are running around 55 lb/hr......
Making about 625 WHEEL HP at 11.50:1 AFR on nitrous.... Duty cycle maxes out at around 75%..... This is with a TH400, ATI 4000 stall, 9"..... Probably making around 750-775 flywheel.....
So for a HP versus duty cycle sample is why I responded....
afr doesn't factor in; bsfc.,observed hp, % of duty cycleXscaling and # of injectors. You need any three to calculate the forth. If fi, you also need the fuel pressure to be referenced1:1 with boost. I am only in this thread because I thought this was too basic for tuners to bother explaining
Is 625rwhp actual or corrected. What are your injectors scaled at? Read post 19. You are aware that this is fwhp math.
this fails if the injectors are not flowing what the computer says.
