Signature Testing & Design Test your sigs here!
What does everyone use for sigpics?
Old May 21, 2011 | 12:40 PM
BrdOPry's Avatar
Default What does everyone use for sigpics?
I keep trying with paint, and its still too large of a pic what is everyone using???
Old May 21, 2011 | 04:13 PM
Asian LSX's Avatar
I use the resize function in Paint and just go a little bit at a time before saving. Then I upload that pic to LS1TECH at the upload sig pic function here in the User CP.
Old May 21, 2011 | 05:11 PM
ramairetransam's Avatar
i requested or asked for someone to do a sig and nothing , who can do one for me .
Old May 21, 2011 | 05:46 PM
JeremyT's Avatar
There are two, free, programs that I personally recommend when needing to edit images:
The Gimp: http://www.gimp.org/
This program can be quite complex, thus, it can take time to learn how to use. However, it's a powerful program when needing to edit photos.
IrfanView: http://www.irfanview.com/
This program is lightweight and pretty easy to use, although it's not as powerful as The Gimp. This program will do your basic editing (setting dimensions, cropping, etc.).
Using IrfanView as an example, which after you download and install it, click on File and Open to locate the image on your computer that you wish to edit. To simply scale the photo down to fit a set pixel dimension, you can click on Image and Resize/Resample. Under the Set New Size, enter the dimension you want the image to be. Make sure Preserve Aspect Ratio is enabled so that the image isn't distorted. With the Preserve Aspect Ratio set, you will only be able to enter a Width or a Height and the system will calculate and fill in the other value to preserve the aspect ratio.
Old May 22, 2011 | 08:43 AM
BrdOPry's Avatar
Thanks for the input, ill check them out!
