Single Digit Club Running 9s or quicker? Damn!
Will it go 9's?
Old Apr 1, 2015 | 09:34 PM
blk99sleekbeak's Avatar
Default Will it go 9's?
02 camaro: stock bottem end (freshened) arp rod bolts, arp head studs, factory unported 243's, trex cam, vic jr, accufab 4150, speedtech diffuser jetted for 150 hit, 1 7/8 headers, vibrant mufflers dumped off collectors, custom ptc converter, rmvb th350 with brake, all umi adjustable rear suspension, drag bar, da qa1's on all corners, bogart d10's with 275/60 et street radial (3754r), race weight is 2900-3000lbs.
Would really like to get in 9.9x's and maybe .80's with some refinement. Seems like it should, what you guys think?
Old May 4, 2015 | 03:46 AM
00MaroonZ28's Avatar
That would be pretty tough to do. You'd have to pull a hell of a 60 ft.
Old Dec 26, 2015 | 10:23 PM
mgood613's Avatar
Did you get it? Sounds like you should have.
Old Dec 28, 2015 | 11:01 PM
k_garretson23's Avatar
you definitely have the weight in your corner but i imagine it being tough for a basically heads cam car on only a 150 hit getting in the single digits. Im praying for single digits with a built 370 with a 235 mamo top end on a 250 plus hit, granted its a stick car.
Old Dec 29, 2015 | 09:55 AM
Dark SS's Avatar
Might need more than a 150 shot but it should do it.
