high compression and starters...
What starters are you guys using?
I did have a powermaster at first but got tired of rebuilding solenoids
How large of cable did you run? And did you run the ground wire too or just to the chassis by the battery?
You need need the same size ground cable from the battery to block as you do positive, larger the better
I run an 18lb deep cycle up front in my car to keep the system voltage drop to a minimum with all the efi stuff that needs it
I may need to look into a different starter, this xs power starter doesn't fit.
