Single Digit Club Running 9s or quicker? Damn!
Hi Comp Motors
Old Jan 8, 2007 | 11:58 AM
Flow Wizard's Avatar
Default Hi Comp Motors
How much Compression are the fast nitrous Iorn Block ls1's running....
My motor is currently being machined and pistons are a 13cc dome and 65cc head. Iwas planning to do a dual stage nitrous setup for a total of 300-400hp
anyone running 15:1 compression or more on that much nitrous?
Old Jan 8, 2007 | 12:14 PM
CorvetteMajor's Avatar
7 Second/200 MPH Club
I ran that much spray with 13:1 just remember the higher the compression the smaller the margin for error.
Good luck
Old Jan 8, 2007 | 01:10 PM
I've followed your build for a long time on CF, Since you've done it before would you recomend lowering the compression to mid to low 13's?
Old Jan 8, 2007 | 01:36 PM
I would if you were running N/A I could see you running 15:1 but on spray that's a lot.
Just my 2 cents Other may feel differently did you post in the nitrous section
Old Jan 8, 2007 | 01:58 PM
Will do thanks
Old Jan 10, 2007 | 08:08 PM
mrdragster1970's Avatar
6 & 8 Second Club
Not an LS motor, but we have sprayed at 15.8-1. All parts were best of the best and it was a old N2O tune up that was used many many times. Good luck.
