What kind of 60's you guys pullin? I'm wondering what it's going to take to get me in the 9s. It should be possible but I'm going to need a good 60'. I'm going tomorrow to make my first full 1/4 passes since the power increase. Last time out I ran out of gear so had to let out after the 1/8. The 1/8 mile time in my sig was with a 1.74 60'. The car should be capable of 1.3-1.4. The best so far was 1.52 but I only made 2 passes and definetly has more in it. What 60' do you guy's think it will take to get my 682rwhp car in the 9s? |
This car took a 1.465 to get a 9.99 @ 136 mph, 6.31 @ 109 mph in the 1/8. Thats at Bowling Green but at another track it took me 1.390s to get in the 9s, wasnt the car though just some tracks will vary a little on 60 foot times. If your mph is in the 136-137 range you have the power to get there. |
Thanks kp. Ran a 10.42 @ 128 today in 90 degree weather with only a 1.5 60'. It may be possible in cool weather and a good 60' but right now it looks more like a low 10 second car. Either way I'm happy running 3 passes in the 10s and then driving an hour and 20mins home all on a stock block and stock 4l60e. Can't ask for much more than that, I was so stressed I was going to blow the trans but it took the beating like a man and neither over heated. It was a good day. |
congrats stock motor...o.k it has been done stock trans... thats crazy at the power level and 60ft at what RPM did the car go thru the traps ? The car will have some better ET/MPH when the good air comes. The temps and humidity today where horrible for a setup like yours. |
Nothing wrong with a 10.40 car in the heat. Just wait until it cools off and you will be amazed how much it will drop. |
Originally Posted by kp Nothing wrong with a 10.40 car in the heat. Just wait until it cools off and you will be amazed how much it will drop. I miss the days with my Z/28 sometimes.... |
im shooting for slowest 60' to get in the 9's.. so far im at a 1.78 and a 9.98 |
Originally Posted by LS1 SPEED for sure...this is a really nie car too ! drive to the track and drive home with a low 10 to high 9 sec ride is awesome :devil: I miss the days with my Z/28 sometimes.... I went from 10.1x in the heat to 9.70s in 60 degree weather with the old engine so I always look forward to fall. |
Originally Posted by LS1 SPEED stock motor...o.k it has been done stock trans... thats crazy at the power level and 60ft at what RPM did the car go thru the traps ? The car will have some better ET/MPH when the good air comes. The temps and humidity today where horrible for a setup like yours. It went through the traps really close but I never hit the limiter or shifted to 4th, I believe it was at 6700-6800 so really the gear is just about perfect for my setup. It only traped 128 though so that means I might be cutting it real close in the cold air if I'm traping higher. |
Originally Posted by kp I miss it too, the safety stuff is what took all the fun out of driving mine. That and my insurance agent seen it :D I went from 10.1x in the heat to 9.70s in 60 degree weather with the old engine so I always look forward to fall. |
I was thinking more... not that it is always a good thing , but The MPH for the HP doesn't seem correct to me....maybe someone a it more experienced can agree or disagree ? do you have HP Tuners to log with ? |
Originally Posted by LS1 SPEED not that it is always a good thing , but The MPH for the HP doesn't seem correct to me....maybe someone a it more experienced can agree or disagree ? do you have HP Tuners to log with ? |
Originally Posted by MIGHTYMOUSE im shooting for slowest 60' to get in the 9's.. so far im at a 1.78 and a 9.98 i'd love to have a 2.0 60' and a 9 second slip |
I trapped 131 and I dyno'd 620rwhp on a dyno jet. the mph does seem a bit low for the hp but I would be happy with those times in 90 degree weather. good luck on getting those 9's Im sure they will come. |
Originally Posted by nvmy2000ss I trapped 131 and I dyno'd 620rwhp on a dyno jet. the mph does seem a bit low for the hp but I would be happy with those times in 90 degree weather. good luck on getting those 9's Im sure they will come. |
| All times are GMT -5. The time now is 10:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
