BBC in 4th gen
It seems very logical to add braces here and here, but the firewall is not very strong.
Any idea how I can make the firewall stronger to act as a structural support
without cracking the windshield? I'm trying not to gut the dash out, but I might have to pull everything out, do all my welding and then put it back in. If you know of an easier way, let me know.
I've thought about this:
I made these up before I decided to relocate the battery and other parts and before I decided to tub the front wheels.
Here's another car with a fabbed up front section.
BTW, there are electric PS pumps ($300) if you want to keep your rack, but not the engine mounted pump. I'm thinking of getting one myself and also run it to a hydraboost brake system. Then I can have power steering and power brakes with the engine off. Big cam making low vacuum? No problemo. Engine dies going down the road, no sweat.
I cut out the rear of my shock tower to save weight and give me more room, I could always mount a turbo on each side right there also if I went that route down the road.
Either way right now it was for weight and gives more room to work on the engine, I may or may not go with a removable front end, if I did working on the car with the extra metal removed makes it a snap to get to the spark plugs.
http://www.otedesign.com/gallery/index.php?a=10
My last car wasn't street legal, 33x16.5 slicks, and lexan windows isn't exactly dot approved. I have my old motor I could say was in it when it was "smogged" if I get popped.By the way are you going to the LA Invasion? I'll be at the Monday memorial day drag racing in Fontana.
Foot brake and make sure the wheels don't fall off is all I am doing first pass and check all the nuts and bolts and look for any extra leaks lol
I took my 1st car to the track 3 or 4 times before I even sprayed it.
