Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
lunati 60205?
Old Oct 28, 2008 | 03:43 PM
proxemics's Avatar
Default lunati 60205?
any body tried this cam ?
waht do you think of it for stock 454 with intake and headers only
Part Number: LUN-60205LK
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 241
Exhaust Duration at 050 inch Lift: 249
Duration at 050 inch Lift: 241 int./249 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 292
Advertised Duration: 284 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.572 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.590 in.
Valve Lift with Factory Rocker Arm Ratio: 0.572 int./0.590 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible
Old Oct 28, 2008 | 06:48 PM
ZONES89RS's Avatar
In-Zane Moderator
That cam would make a big block run great, especially for a street toy.
Old Oct 28, 2008 | 07:46 PM
slow95z's Avatar
it would be turd on the bottom and not peak at that specified rpm due to the intake falling off and lower compresion.
Old Oct 28, 2008 | 08:48 PM
analyte's Avatar
For a stock 454 with only minimal bolt on's I would say no bigger than the 60203. I'm running the 60204 with 10.3 comp, 800 carb, and big valve heads followed by a T56 with 3.73's. The 60205 was too much for me with my 454 .
Old Oct 28, 2008 | 10:00 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, that is why i said it would run great and not bad ***.
Old Oct 29, 2008 | 02:21 AM
proxemics's Avatar
I have this cam and I can use it today
a friend of mine orderd the summit cam
Duration at 050 inch Lift: 238 int./248 exh.
Advertised Intake Duration: 296
Advertised Exhaust Duration: 306
Advertised Duration: 296 int./306 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.540 exh. lift
Lobe Separation (degrees): 114
it will arrive here next week and I can have it, which one do you recommend?
