Track Trip
What springs would you recomend?
How many miles are on the motor? If there aren't many miles, and your vacuum gage shows what appears to be valve float, it could be the lifters also.
I thought about throwing some heads and a cam in it but idk if that bottom end would hold any power.
The cam specs are real mild and the compression is pretty low on that crate engine. I think it will be all done by about 5000RPM. Super Chevy did a test with one of these engines. In base form it peaked at 264HP at 4400RPM. They then bolted a blower on it and made some serious power (383HP at 5500RPM on 7psi of boost).
If it were me, I would go over the motor good. Use your vacuum gage. Try to diagnose what is going on at the 5000RPM. Get the carb in tune and play with your timing. The secondary valve on the quadrajet (the plate that covers the top of the secondaries) can be a great tuning aid and there is power to be found there (you want it to open as fast as possible without bogging the motor down). Also, many smog era quads were limited in how far the secondary throttle blades could open. Verify that they are making it to full-open.
The short block is a decent foundation to build from. If you plan on keeping it, I would go with a head and cam swap.
so do you think all that and a 75-100 shot would work on that bottom end?
how fast do you think it'd run in the 1/4?
Im kinda leaning toward building a motor cuz i want something very reliable idk though.
What kinda valve train set-up would u go with?
and Cal-Tracs are made for my suspension... like 85 bucks!
