Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
EFI 454+LT1 computer
Old Nov 11, 2008 | 07:45 AM
BlownEarDrums's Avatar
Default EFI 454+LT1 computer
I'm curious about converting a 1990 454 SS truck motor to EFI and putting it in my 95 LT1 chevy caprice. I looked around in C.A.T.S. and it look like i could change the tables and values and get the motor to run right with a crank trigger in place of the opti. Has anyone attempted this?
Old Nov 11, 2008 | 08:18 AM
T/ALT1's Avatar
I also contemplated doing that but wasn't sure how hard it would be to make it work properly. I am sure it could be done but it will take alot time and patience to get it right. Goodluck.
Old Nov 11, 2008 | 01:30 PM
ulakovic22's Avatar
I wanted to try it out but decided against it. I do know that you will need more than a crank trigger to run the LT1 computer. On top of a 4x crank signal you will also need a 2x cam signal so the computer knows what cylinder is firing. This could be acheived I believe by welding a magnet/pickup to the timing cover. If I had the time and money I would defintely attempt it.
