Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Water temp sender location...
Old Dec 25, 2008 | 05:54 PM
camaroboricua's Avatar
Question Water temp sender location...
I hooked up the heater core in my car b/c its been getting too freaking cold to drive around with no heat. So I had to remove the sender from the front left of the intake to the top left on the radiator. I couldnt put it by the water neck b/c its too tall and it gets in the way of the hose. Should I leave it on the radiator or should I try to put it on the intake using a 90* adaptor. I think its too high up on the radiator and also not as accurate. Any ideas???
Old Dec 25, 2008 | 08:50 PM
9000th01ss's Avatar
I'd put it in the cylinder head.
Old Dec 25, 2008 | 09:40 PM
I didnt know I could do that. Where would it go? I saw a plugged hole on the pass head but was unsure if it would be the right one.
And now that I think about it I think theres one on the block also, that I forgot to plug when I first istalles the engine and all the water was coming out through it. Ill have to check it ut in the daytime tomorrow or sat.
Old Dec 25, 2008 | 10:02 PM
9000th01ss's Avatar
Yes, drivers side front was the factory location on a lot of gen 1 small blocks. And obviously the pass side head has the same hole toward the back.
If you had the sender in a heater hose hole on the intake you may need a different adapter for it if you have heads with center bolt valve covers. The later heads use a smaller hole.
Old Dec 27, 2008 | 06:44 PM
Thans for the advice^^^^ I hooked it up today to the pass side head and it works great.
