Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Wtf is this plug?
Old Jan 7, 2009 | 12:15 PM
gayslowassNALSjunk's Avatar
Default Wtf is this plug?
I have a '74 Nova that has a moderate 355 in it. A couple of months ago it started leaking oil that progressivly had gotten worse and worse. After a bit of inspection I believe it was coming from the oil pressure sensor. However, this was not the case. I removed the driver's side head to find a plug on the deck of the block that's half covered by the head. Somehow this had come loose and was spewing oil down the back of the engine. I'm now looking to fix the leak and I can't seem to find anybody that knows what I'm talking about. Is there any specific torque spec or way to keep this little bad boy from backing itself out again?
Old Jan 7, 2009 | 12:18 PM
96lt1m6's Avatar
i have used a small amount of thread sealer on this little plug.
Old Jan 7, 2009 | 12:20 PM
Nice! Atleast you know what I'm talking about.
Old Jan 7, 2009 | 01:32 PM
9000th01ss's Avatar
It's a tapered pipe plug.
I've never heard of one coming loose.
Might want to check the threads, make sure they're not stripped.
Old Jan 7, 2009 | 03:55 PM
ctg0305's Avatar
1/4" npt plug if we are talking about the same thing.
Old Jan 7, 2009 | 05:42 PM
9000th01ss's Avatar
Yes, 1/4" National Pipe Thread
It would be very, very odd, but if this plug was installed at a machine shop they may have, by mistake, installed a orificed plug for the cam oil galley in a big block chevy.
So make sure it doesn't have a hole drilled in it.
Old Jan 7, 2009 | 07:19 PM
ZONES89RS's Avatar
In-Zane Moderator
Oh man, make sure there isnt a crack while your at it tight there in the deck.
Old Jan 9, 2009 | 09:34 PM
cnorton's Avatar
Either way, the head is going to need to come off. It's a pain in the butt but that's the only way to get to it.
Old Jan 9, 2009 | 09:53 PM
9000th01ss's Avatar
Originally Posted by cnorton
either way, the head is going to need to come off.
first post.
Originally Posted by gayslowassnalsjunk
i removed the driver's side head to find a plug
