Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Braided radiator hose?
Old Jan 16, 2009 | 01:04 PM
BassProCamaro97's Avatar
Default Braided radiator hose?
I wasn't sure where to post this but I figured the older engine crowd was the most likely to have braided radiator hoses.
SO, my question is where can I find the fittings and hose for upper and lower radiator hoses?
Also does the radiator need to be fabbed diffrently from the maker to accept the fittings or will an off the shelf rad work? What size fittings are you guys using?
I'm setting up my 97 and I'm going with a vertical radiator. I'm using a griffin.
Thanks
~Jim~
Old Feb 2, 2009 | 10:29 AM
98 Silver Bullet's Avatar
I'm using a Howe radiator and I thought about going with braided lines. It was going to be close to $300 after having -16AN fittings welded to the radiator and for the hose, & fittings. I went with Goodyear flexible hoses instead. You can purchase all you need including the aluminum -16AN weld on fittings for the radiator from Jegs/Summit.
Old Feb 2, 2009 | 11:33 AM
Thats eventually the conclussion that I came to.
I'm going to go with a regular rubber hose then wrap it in this braid look alike sleath. They have hose clamp covers that look like AN fittings.
Cheaper way to do it but you get the same end result sort of.
~Jim~
