Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Big Block TKO 600 ????
Old Feb 21, 2009 | 10:53 PM
EastTnZ28's Avatar
Default Big Block TKO 600 ????
I bought a TKO 600 off of a guy on here with the flywheel, bellhousing, slave and master a while back and have some questions about the flywheel. The tranny and everything else came out of a 94 LT1 car and for some reason I thought the flywheel on the cars was the same as the early model V8's. I found out that there not. Big Block and Small Block will not interchange. I guess since the bellhousing will bolt up I thought the flyweel would too. Well any way, if I get the right flywheel will the Centerforce clutch that was for the LT1 car work on my big block?
Old Feb 22, 2009 | 11:26 AM
slow95z's Avatar
yes. the clutch will work. you just need the correct flywheel for you motor.
Old Feb 22, 2009 | 09:40 PM
EastTnZ28's Avatar
Thanks. That is what i was hoping
