comp cams 305h
If you have 8:1 compression, they are both too big.
If you have an automatic with a stock converter, they are both going to pull through idle.
If you have a 600 cfm carb they are both too big.
Do you get the point?
You need to list full engine specs. You can't guess at compression ratio.
Also list trans type, converter if it's an automatic, gear ratio.
I see you have listed a 1967 camaro with a 355. The cam is going in a 350, maybe it's a different engine and car, I don't know.
I had a 406 with a ST10, 3.73 gears.
Also a weiand x-cellerator intake, 750 vac sec.
It was in a '75 nova, it would pull hard at 3000 and up, seemed like 3rd never quit pulling. It went from 14 in the 1/4 to 13 flat in the 1/4 just by adding the 292 magnum.
You really need to cc the heads and pistons, and measure gasket thickness, piston to deck height, etc.
