Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
350 to a 383
Old Apr 2, 2009 | 04:11 PM
ChevyS10sbc's Avatar
Default 350 to a 383
Okay Just found out today that my block needs to be .40 over. If I order my 383 kit with .40 pistons what is the acutal cubes?
One more Question.
I had 415 horse power with my 350. What kind of numbers should i get from just the bigger cubes?
Thank you very much guys!
Old Apr 2, 2009 | 06:50 PM
kenSS's Avatar
it is now a 385"
Old Apr 2, 2009 | 06:57 PM
NemeSS's Avatar
engine hp will be determined by cylinder heads, cam scr, dcr, intake etc.
but the bigger engine will use up the heads more and make more hp and tq as is
Old Apr 2, 2009 | 07:25 PM
500hpZ06's Avatar
30-40 additional HP if you keep everything else the same.
Potentially more torque (40-50 add'l), depending on the current combo. I assume you will be upping your compression, slightly?
Old Apr 2, 2009 | 10:27 PM
Yup, 10.7.1 on the commpression.
3.750 stroke
4.040 bore
384.5 CI
6.3L
haha
Old Apr 3, 2009 | 12:44 PM
NemeSS's Avatar
what heads and intake?
Old Apr 3, 2009 | 03:51 PM
ZONES89RS's Avatar
In-Zane Moderator
Ok....i thought i posted this but:
At the general efficiency of 1.5 HP per cylinder, you should gain about 47 HP.
Old Apr 3, 2009 | 04:09 PM
64cc 215cc 2.08"/1.60" N/A #77589* Vic jr heads
RPM Air-Gap (1500 - 6500 RPM) Mani.
Old Apr 3, 2009 | 05:38 PM
KCS's Avatar
KCS
Moderator
One more Question.
With the same heads and cam, it should make about the same peak numbers, but make more power "under the curve" with more displacement. Extra compression should be worth something though.
Old Apr 4, 2009 | 06:21 AM
dedon500rt's Avatar
i've noticed guys with 4k+ stall will not see much gain in ET. Like KCS stated, they'll make more power under the curve which you'll never really see with a loose converter since they "flash" up around the max power quicker.
i probably failed at making since.
