Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
white smoke
Old Apr 16, 2009 | 11:54 AM
lifeisgood's Avatar
Default white smoke
i have white smoke after a new set of lifters went in.
is coolant the only thing that could cause this?
i torque the manifold down in sequence at the proper torque spec.
i dont believe its the intake leaking, i ve done so many of these.
but what else could it be.
its a full size chevy with 168k miles on it. stock
Old Apr 16, 2009 | 01:00 PM
ZONES89RS's Avatar
In-Zane Moderator
So, this is initial start up or it constantly does this now?
Old Apr 18, 2009 | 12:40 AM
lifeisgood's Avatar
i thought it was constant, after a test drive it was still doing it but upon start up now it has chilled out quiet abit
Old Apr 18, 2009 | 01:37 AM
ZONES89RS's Avatar
In-Zane Moderator
Valve seals could be he culprit.
Old Apr 23, 2009 | 09:15 PM
irocz2173's Avatar
why are you thinking valve seals? that would be blue.
I would suggest checking the oil and making sure you havent made a milkshake. Really there are only a few things that could have happened,
1. head gasket blown
2. intake gasket bad (either not seated properly or torn)
3. crack in a coolant passage.
Is it better/worse when warm?
Give us more info
