Quick question on BBC conversion
Was wondering if I absolutely need aftermarket a-arms or can I use stock?
Do I need a new engine cradle?
Also, how difficult is it to remove the motor from the top of the car?
Any help is greatly appreciated.
I am on the verge of buying a 486 big block, with a th400.
I just need to know what all i need to buy in order to make it work.
A-arms don't matter
New cradle is easier than trying to make the stock one work.
You can pull the motor trans out the top together if you pull the manifold/distributor. Short block will pull out just fine but you have to turn it sideways on the way up.
