What BBC rotating assy?
The block was previously set up .030, stock crank and rods with forged pistons. Heads I currently have are Brodix BB2 Plus, Intake is a port matched Victor Jr; I'd like to keep this combo on the top end. Any input on this is appreciated.
Thanks
Stock block is not going to live long with big boosted HP. Plus unless it's a full race chassis,
you will never use all the power anyway. I was actually considering going from the stock 4" stroke to a 3.75
to help with traction by killing some torque. With such a vague, no information post, it's hard to help.
Are your goals 500 HP or 2000 HP??
eagle does a few nice kits though:
1st kit $1849.99 850hp-1500hp capable
460c.i. depending on your bore
4.000 stroke
6.385 rod
srp flat top pistons
112cc 118cc 124cc
comp. 9.0 8.5 8.3
2nd kit $1949.99 850-1500hp capable
489c.i. depending on bore size
4.250 stroke
6.385 rod
112cc 118cc 124cc
comp. 9.5 9.1 8.7
3rd kit is forced induction kit $2349.99 1500hp capable
460c.i. depending on bore size
4.000 stroke
6.385 rod
je dished pistons
112cc 118cc 124cc
comp 7.9 7.7 7.4
if intersted in anymore info give me a call
GRAND PRIX AUTO SPORTS CENTER
4915 ADMIRAL PL
TULSA, OK 74115
1(800)331-2223
ask for chris
Sorry for such novice questions, just trying to learn a little.
You really need to know how much chassis you will have.
You can't throw 600 HP at some 40 year old stock suspension. As I said, stroke will make it harder to handle.
Torque really likes to find the weakest link. With it being a street car, I hate to say it,
but you might look at a turbo 427" combination. You will make 400+ HP easy on engine
& you can control how far you go from there.
You really need to think as a total project. You can't get some big fancy engine & then can't find a car to hold it.
Trust me, I have been around a little. I ran in the 9's @ 140 mph with a stock '70 Camaro.
It was not easy, and I wasted a lot of fuel & tires trying to get it to work. Good luck.
I guess I came across a little misunderstood. I am looking for a classic car because that is what I like; I do plan to put together a car that wil be able to use this power. This is why I think anything much more than 600 hp would be a waste. I currently have my 2000 SS which is a 400+ hp high 11 sec car, and as much as I love this car, its not what I am really wanting. I would get a lot more pleasure out of driving a classic car with some BB torque to move it...my big focus is the car not major power; but, I do want to build a motor with potential.
I need a rotating assy regardless, I gave my stock one to my father for his motor. So my question here was what rotating assembly should I consider for what I am going for? I have to buy one anyway, so why not stroke it right? My power adder of choice is boost if I decide to add a little hp.
i love turbo cars, i've owned two and there is nothing like hearing the turbo spool up then all of a sudden you are gone!
At least that makes some sense. So give us a clue what car you are leaning towards.
That way we know if it's leafs, factory 4 link, torque arm ect. Big difference between a 4000 lb tank & a vega.
I still like a short stroke with boost. Easier to control traction.
Plus with boost you can use cheap fuel when needed or better yet get the benefits of Ethanol.
Wish you were closer, as you can probably tell, I'm a BBC guy.
My crew chief & I have built many many combinations over the years.
We have a couple of ideas that work pretty decent.
I definitely am not looking to just slap something together and be done with it. I want to learn while putting this together and put together a great working combo with no wasted power. Im sure I can just order a built shortblock for a good price and slap my heads on, but Id like to put a little more thought into it.
I guess I am looking from completely different perpective. My plan was to set my goal at about 600 hp with plenty of potential in the motor for more hp, pick the car, then build the suspension to make use of the power I plan on putting down. I never really thought of picking the suspension then build the motor to it. But, I was thinking to probably go with an aftermarket 4 link in the rear (a whole other learning curve for me). And the car will probably be a tank, I like the 64-67 Chevelles a lot; it will be a full interiored car. Hopefully that is what I find once I sell my Camaro.
So, if you just WANT a boosted engine, you need to just go with the stock stroke, even as mentioned, a 427 crank in the 454 block.
I am doing a 496 with oval ports and hyd roller in my 89 RS, it will have a shot of dope on it, about 150 for the street "IF" i ever use it will be in question till i go to the track. I will be using a 6 speed trans too, with a clutch and 4.30 gears it is going to be a toy. Hard to make that hook on the street really, but it will be a blast.
It is hard to set up a engine without knowing what it will be in, a heavier car can get by with the extra torque VS a lighter car(like my 89 RS) will be so much harder to hook without big tires and better than leaf spring suspension.
Not to mention, do you want to build a retro roller, solid roller, a flat tappet even?
I really love the Camaro, but trying to go with something different; I would say Im about 75% sure Ill be picking up a Chevelle, therefore that is what I will build for. If I do pick up a classic Camaro or something else light, then I can build the 400 Ive been wanting to put together.
I plan on going with a solid roller setup. What I want, is a little flexibility to be able to add some power later on if I wanted without having to rebuild the motor. A cam swap for the boost would be fine, but dont want to have to tear apart the motor for it. I am willing to sacrifice a few all motor hp for such a setup.
Good luck with your BB in your 89. You may already know, but Ill just mention a few things for you. The headers (I used Hooker Super Comps) are going to heat up your brake lines pretty bad, you will need to reroute them. If you decide to install aftermarket heads, the headers will give you more problems than you can imagine...lots of modifications to make them work. Tall valve covers will not work with the stock brake booster. And lastly, consider an oil filter relocation kit if you use these headers. But then again I was 17 and I thought I could just drop it in and all would be smoth as glass...
As for you, the problem is, the lower compression will hold back power if you want boost later, it will still make power, but you will know,"Man, if i had more compression i would be making a lot more power..."
But some of us can wait. I am going for lots on motor and some gas when i need it, if i was you i would go ahead and build it for boost and boost it once it is in the car. But a big block with boost is going to make earth spinning torque that will be best in a chevelle or heavier car that can stock a bit better.
what size tubing? 2"?
