Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
e85 guys...
Old Sep 3, 2009 | 09:21 PM
04gtoBMXracer's Avatar
Question e85 guys...
well im almost finished up with my 87 sbc supra, i went with the quickfuel 750 e85 carb and holley blue fuel pump with reguator, are you guys having a hard time getting your cars running good? what af ratio are you guys seeing the best results? how much timing? i was also wondering about plugs. its a stock 350 crate gm goodwrench motor 9:5.1 i think, stock now but i have a 150 shot kit and a pretty good size cam/vortec heads waiting to be installed. thanks.
Old Sep 9, 2009 | 07:15 AM
fossilrunner's Avatar
your carb could be a little big for the stock 350. a 650 would probably be better suited, but once you start upgrading everything else the 750 would be the better choice.I dont know what af ratio im running but heres my motor set up
motor is a 355
186 double hump heads(fully ported and polished)
vic jr intake
holley hp 750 with quickfuel metering blocks and mainbody
(83/90 jets and #31 squirters)
11.5:1 compression
custom lunati cam(.520/.540 lift 290/300 duration 240/250 @.050 106 lsa)
Mallory HYFIRE VI Digital box
MSD billet distributor
NGK UR6GP plugs
Motor runs on E85
intial timing at 18*
Total timing set at 39*
Old Sep 9, 2009 | 03:38 PM
ZONES89RS's Avatar
In-Zane Moderator
Problem is, depends on where you get the fuel. This is something a new friend told me.
E85 is 85% Ethanol. Problem being, one place that sells it, it might be 97%, another might be 70%.
So it will always be a PITA to tune it and get it right.
Old Sep 9, 2009 | 11:38 PM
he can always buy rocket brand e85 to be sure its 85% everytime but its pricey.
Old Sep 10, 2009 | 11:32 PM
thanks fossilrunner, i wanted to get the 600 cfm but the carbs are too damn expensive to be changing often lol, i got it running last night and the motor sounds really good. thanks for the advise. what fuel psi are you running? i got mine set to about 7psi it seems fine idk i havent gotten to do some wot runs yet though.
Old Sep 11, 2009 | 11:33 PM
I keep mine at about 7 too.
Old Sep 24, 2009 | 07:22 AM
loser187's Avatar
You can buy a WB02 and tune that way, or tune it on gas with the old check a plug method then do the math on how much to richen up the carb for e85 and that should get you close.
e85-90 is summer blend and e70 is winter blend from what I have read, so just find out when they change over at your local pumps...
