Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
GM Gen 6 454 timing chains
Old Sep 23, 2009 | 01:16 AM
twinturbo496's Avatar
Default GM Gen 6 454 timing chains
Does anyone here have experience running the factory Gen 6 GM timing chain above 7500 rpm?
The setup uses about 1/2" pitch single roller chain. Here is the GM description.
12371053 - Timing Chain Kit 502 Engine
This heavy-duty timing chain assembly is used on all second design 502 Gen VI with roller lifter engines with aluminum front timing cover. This kit includes crankshaft sprocket P/N 12550039, camshaft sprocket P/N 12551401, chain P/N 10114177, camshaft retainer P/N 10168501, three hex bolts P/N 9424877, two bolts P/N 14093637, and use these components for replacement service
Thanks,
Craig
Old Sep 24, 2009 | 07:17 AM
loser187's Avatar
With the spring pressure and heavy valve train I wouldn't run anything but the best double roller you can find. Crane makes a 2 piece timing chain cover that will clear no problem and also has provisions to adjust the cam clearance/access to degree cam while assembled.
Old Sep 29, 2009 | 07:41 PM
niceguyyy01's Avatar
If it were me, and I was gonna turn any Rat motor over 7500rpm, I'd have a Jesel on there... no questions asked.
