Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Solid roller or Hydr. Cam sbc 355
Old Sep 29, 2009 | 02:56 PM
airforcefun's Avatar
Default Solid roller or Hydr. Cam sbc 355
sbc 355
eagle forged internals
125 shot
9.5:1
Buying AFR195s
wat should i go with a solid roller or a hydr. I dnt mind adjusting the solid roller cause i do that now.
Custom Grind?
Old Sep 29, 2009 | 04:38 PM
ZONES89RS's Avatar
In-Zane Moderator
For max power, i would use a solid roller, but with that compression, might as well go hydraulic.
If you want to tell a cam company what you have and what you are doing with the engine, a custom grind will usually net the best power.
A off the shelf is just quicker to get ahold of.
Old Sep 29, 2009 | 07:13 PM
i can up the compression. it has 76cc heads at the moment. what will 64cc heads raise the compression to?
Old Sep 29, 2009 | 07:50 PM
ZONES89RS's Avatar
In-Zane Moderator
Probably about the 10 to 1 area, the engine will like that allot better and respond more aggressively with a nice cam.
Old Sep 29, 2009 | 09:38 PM
sounds good to me then.. il get the afr195's 64cc and a custom grind.
Old Sep 30, 2009 | 01:35 AM
ZONES89RS's Avatar
In-Zane Moderator
Excellent, give Howards cams a call or Comp cams. Howards is a bit cheaper but very good.
Old Sep 30, 2009 | 07:06 AM
mrdragster1970's Avatar
6 & 8 Second Club
Track only?? you can't beat a roller and as much compression as possible for building power.
I'm using my 1st Howards cam, runs great so far.
Old Sep 30, 2009 | 02:54 PM
thanks guys
Old Oct 4, 2009 | 12:00 AM
Should i chang my intake? ive got an rpm air gap on it now
Old Oct 4, 2009 | 12:05 AM
well itll be primarily track. but ill drive it to my local car show..
Old Oct 4, 2009 | 09:34 AM
NightTrain66's Avatar
LS1TECH Sponsor
definitely go solid roller, just make sure you have the budget for good springs, rockers, pushrods, etc and tell who ever does the cam what parts you are running so the parts live.
Lloyd
Old Oct 4, 2009 | 11:05 AM
How about the intake? I know its only rated to 5500rpm. should i get a vic. or a vic jr.?
What push rods should i go with?
Old Oct 4, 2009 | 08:21 PM
AutoRoc's Avatar
RPM Air Gap is advertized as 1500-6500rpm. In a small cam, 355, with AFR 195's, it's probably the best choice. Doing a Vic Jr. will get you more hood clearance, and more power past 5000rpm but it will lose TQ down low. Nitrous makes GOBS of torque down low so if you aren't worried about power off of the hose, i'd switch to a Vic Jr but if you want to drive it and have good bottom end power, keep the Air Gap. I'd try the Air Gap if I already owned it!
Lloyd Elliot above can set you up with a fantastic solid roller for the street. He uses the best parts avaliable and is FAST.
