Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Compression question.
Old Dec 2, 2009 | 07:28 PM
GatorFan08's Avatar
Default Compression question.
Im buying a 454 with 13:1 compression, and was wondering If could drive it on 93?? Its going in my weekend warrior, anyways the only reason I asked is because my buddy's 383 has 12:1 and runs 93 with NO PROBLEMS.
Old Dec 2, 2009 | 09:10 PM
ZONES89RS's Avatar
In-Zane Moderator
Wel, if it has aluminum heads and you run the timing WAY back, yep.
Old Dec 2, 2009 | 10:58 PM
mrdragster1970's Avatar
6 & 8 Second Club
I wouldn't say no problems, but as mentioned.
If you choke it way down and don't hammer it, who knows??
Old Dec 3, 2009 | 05:57 AM
cambirdracing's Avatar
I had a Pontiac that I tried to do that with. it got to where I could change the head gaskets in any parking lot in less than a hour.
Old Dec 3, 2009 | 07:08 AM
pancherj's Avatar
There is a good real lead fuel additive out there called Kemco. I plan on using it in my 489 with 12:1 compression and iron heads. The guys over on Chevelles.net rave about the stuff. I haven't checked into the price yet...
Old Dec 3, 2009 | 09:29 AM
6 & 8 Second Club
If you have a real fuel system on there, it might be cheaper to just use E-85 if available.
Old Dec 8, 2009 | 03:29 PM
1 FMF's Avatar
it would depend on cylinder pressures, but those are variable and dependent on other variables.
you can use the dynamic compression ratio, which depends on camshaft profile, to get a better feel but it won't guarantee that a certain octane fuel would not detonate under various conditions.
http://www.kennedysdynotune.com/Dyna...ion%20Tech.htm
http://www.empirenet.com/pkelley2/DynamicCR.html
http://www.hotrod.com/pitstop/hrdp_0...ion/index.html
Old Dec 8, 2009 | 05:18 PM
RedGut86's Avatar
Ouch.
Definitely check out what the dynamic CR is as linked above. Pat Kelley is a great resource with some good free tools. I have run slightly higher DCRs than his recommended numbers with a aluminum heads without problems, but YMMV.
Old Dec 12, 2009 | 12:31 PM
tom falco's Avatar
Its all in the DCR. If the valves stay open longer the mechanical compression ratio means nothing. Check the DCR and that will tell the story. I run 12.5 -1 with no problem in my Chivelle. Big block
