Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
How much power will I make?
Old Mar 26, 2010 | 11:31 PM
D79's Avatar
D79
Default How much power will I make?
Its everyones favorite thread. I have an estimate on what the engine will make at the crank and the tire but I'm curious to see what you guys think.
355 SBC
Trick Flow 64cc heads w/ 195cc intake runners(flow 300+ at .600)
10.5:1 compression
Solid Roller cam 236/242 @ .050 .602/.608
Single Plane Intake
750cfm Quick Fuel Carburetor
anything else?
Old Mar 27, 2010 | 06:59 AM
ZONES89RS's Avatar
In-Zane Moderator
If you have a stock TH350 and a 10 bolt 8.5(i doubt since it is a 6 cyl car in your sig), i say 400ish depending on a stall, with a TH400 and a 12 bolt/ 9 inch, high 300s, so 380-420, anywhere in there, autos read funny on the dyno also, so it is a hard call, that motor if right should make 500 HP at the fly..
Old Mar 27, 2010 | 11:58 AM
D79's Avatar
D79
Right on the money there zones. It is a TH350 with an 8.5 differential. The stall is a 3500 with a 2.5 STR. What can I expect at the track realistically with a drag radial and some rear suspension work?
Old Mar 29, 2010 | 12:20 PM
h0t's Avatar
h0t
Sounds like a nice motor but I'm VERY skeptical about the CFM flow you've stated.
For example:
I have a set of Dart Pro 1 CNC machine heads, 66cc chambers, 227cc runners, and they flow 319 cfm at 0.700 lift.
You have 64 cc chambers, 195 cc runners, and say 300+ at 0.600 lift? I could be wrong but you might wanna double check that.
Either way, I like the cam . I'd say 525hp depending on your engine accessories (electric fan, electric water pump vs. a regular water pump/fan, AC, etc etc).
Old Mar 30, 2010 | 01:35 AM
D79's Avatar
D79
For example:
Thanks
you may be right on the flow on the heads. I never have them flow tested, just going off what I was told by the man who sold 'em to me. They have been ported and polished.
Only accessories ill be running is a water pump and power steering.
Old Mar 30, 2010 | 04:33 AM
Mike Broadway's Avatar
Maybe 15 to 20 hp on a good day!! LOL
Old Mar 30, 2010 | 12:31 PM
D79's Avatar
D79
ha, i can only hope *knocks on wood*
