How to adjust timing on '88 IROC
To change the timing, loosen the bolt that keeps the distributor tight(the distributor is the big circular thing on the back of the engine). Then you grab onto the cap and turn it. One way will advance the timing, the other will retard it(lessen the number). Im not sure but i think counterclockwise will advance it. But be careful and only turn it a little bit at a time. Turning it too much can damage the engine. Once the line on the balancer matches up with the appropriate number on the tab, tighten down the distributor and you are all set.
Hopefully this helps a bit. Much easier than it probably sounds. Also would be a good idea if you had someone who knows what they are doing there to help you.
