Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
sleeved cylinder???????
Old Jul 9, 2010 | 02:29 PM
greenturtle05's Avatar
Default sleeved cylinder???????
Is anyone running a sleeve in any of the cylinder of your motor? my reason for asking is because, i bought a 400 block a while back that i was going to build and it has a sleeve in one of the middle cylinders. i can't remember why the guy put the sleeve in it. i was gone do a pretty mild street built 406. should i use this block or look for another one? whats the pros/cons of this block? its also standard bore. thanks in advance.
Old Jul 9, 2010 | 03:27 PM
ZONES89RS's Avatar
In-Zane Moderator
If a god machine shop gives it the go, i would say use it. Otherwise, they are the pros.
Old Jul 9, 2010 | 09:25 PM
SanitysBane's Avatar
If the sleeve has been properly installed there are zero problems running it.
Old Jul 9, 2010 | 11:48 PM
chevelledave's Avatar
Got 2 in my Bowtie block ...14 1/2 to 1 no problems with it ..if its done properly
Old Jul 10, 2010 | 01:13 AM
the guy that i bought the block from does his own machine work, and he did the block so im hoping that it should be ok.
Old Jul 11, 2010 | 07:08 PM
kenSS's Avatar
If done correctly it will be fine. I put alot of sleeves in motors. I actually put all 8 sleeves in a SS/AH hemi motor 3 years ago. Still going strong at 9200 rpms.
Old Jul 26, 2010 | 09:01 PM
CNC BLOCKS N/E's Avatar
The 400 blocks are the worst ones to sleeve beacuse the sleeve is so close to the head bolt hole they tend to crack when torqued up and it will distort the shyt out the cylinder or cylinders its next too. 400 blocks should be plate honed as they have weakest decks and cylinders.
Its hard to compare a 400 block to a Bowtie or am I missing something here.
Its a good idea to have the block sonic tested before any work is done to see if the cylinders are thick enough,
Here is a link to look over
http://speedtalk.com/forum/viewtopic...ing+400+blocks
