Belt Squeek
SBC question. I have a 305 in a Ford Roadster. Long and short, I had to replace the alternator. Now there are only 3 pullys on this engine, Alt, Water pump and crank. The belts on it are the thin V style belts. Once I replaced the alt, I put it back together. The only way I could tell to make the belt taunt was to adjust the alt in a way to take the slack out. Its nice and tight and about 50% of the time, the belt squeels horribly. The alt is new, water pump bearing is good, belt is good........I am at a loss.
Anyone with any suggestions? I want to stay away from dressings and all.
The belt is the same one that was on the application before I had to have the alt rebuilt.
I wish I knew more about it, but its a custom build that my late father did. It would be easier to ask him if he had this issue when he built it, but a little hard to do now, so I have to work with what I got.
Throwing this out there. The alt pulley and the water pump pulleys are chrome. Is there anything special that needs to be done with them? Also I have heard of the pulleys getting a glaze on them over the course of time from the belts. How would one remove this glaze?
