Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
454
Old Nov 11, 2010 | 10:52 PM
moejoe's Avatar
Default 454
hi i was just wanting to know if i can use heads with a casting number 336781 on a 1994 454 and still use the tbi thanks for any help
Old Nov 14, 2010 | 09:30 PM
Jays_SSZ28's Avatar
Yes, those are Mark IV heads and a 1994 is a Gen V block. The coolant passages are different but victor makes a gasket that will allow the use of those heads on that block.
I've run 781's with the stock peanut port TBI intake and it does give it more power, but you'll benefit more using an Edelbrock TBI intake. The Edelbrock intake still needs to be ported to match the large oval port heads. Or an easier route would be a carb intake with a TBI adapter.
Old Nov 17, 2010 | 10:54 PM
moejoe's Avatar
thanks for the info was also wandering can i you a 454 from a 1984 and use the tbi with an adapter plate
