Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
SB head casting
Old Feb 1, 2011 | 06:03 PM
paul407's Avatar
Default SB head casting
I read that head casting #14102190 is a poor design head for performance and the problem begins around the 4200 - 4500 RPM mark with it being a "swirl" head. Here is my situation, I received a rebuilt marine engine (350cid 260 HP) with these heads. Do you think any problems will arise? I'm running a carter 4bbl (stock Mercruiser intake/carb) and dont really run the motors over 4000 RPM's.
Thanks for any input, Paul
Old Feb 4, 2011 | 11:56 PM
01badz's Avatar
their problem is the intake flow is horible on them for performance. their made for fuel economy and torque. they flow like 195 cfm @ .500 lift i believe.
other than that as long as machining was done correctly they should run fine.
