Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
peak hp
Old Feb 21, 2011 | 07:56 PM
straightleg's Avatar
Default peak hp
does the cam duration dictate where the horsepower peak is?
I ran 13.2 when I dyno'd my car it made 337hp rear wheel hp@5440rpm
I now run 12.25 only thimg I've changed is I pulled 70lbs of wieght between me and the car, freed up hp with electric water pump, fans, and ram air duct to the carb.
so if I'm thinking correctly I should still peak @ 5400rpm but I've freed up more usable hp.
reason I'm wondering because I'm triing to select a new rear gear that matches my peak hp.
Old Feb 22, 2011 | 09:33 AM
pancherj's Avatar
What size rear tire? Is this more race, street or 50/50?
Old Feb 22, 2011 | 03:28 PM
27" Tire, 90% Race
Old Feb 22, 2011 | 06:27 PM
pancherj's Avatar
I'd go with 4.10's now. You will probably cross the line at roughly 6200. The engine should be able to hold on to that RPM. I would shift at about 6000RPM if peak was 5500RPM.
I cross at 6400 with a 26.5" tire, same trans and a 3600 stall. I switched from 3.73's and it wasn't a huge RPM increase. Car likes it, but I could use a higher stall (4500 would be about perfect).
Old Mar 11, 2011 | 09:04 AM
newschool72's Avatar
that 700r4 trans has a really low first . be careful that u dont gear too low or traction might be a problem
