What will porting my intake do?
My advice would be to keep it conservative and not get crazy. Only gasket match (if that much) on the runners while trying to keep them all even. The plenum is where you wanna do the majority of your work by smoothing and bullnoseing all rough edges. Even the devider piece in the middle. When it comes down to it all intakes are rather just pot metal. I myself have had two professional products manifolds with great sucess. Only downfall is the amount of porting it takes to get them straightened out. Lol.
1. Get some thin cardboard or posterboard cut out to the outside shape of the gaskets to make templates.
2. Cut out the bolt holes so that you can bolt them to your heads.
3. Use a razor knife to carefully cut ports in your templates to the exact size and shape of your head ports. Make sure you mark them for L & R.
4. Now bolt them to your intake and use them to scribe where you need to port it to match.
This is called port matching (versus gasket matching) and gives the best results. If you gasket match your intake, you could very well end up with ports in it that are larger than your head ports which causes reversion and poor flow. Worse than if you had ran your intake out of the box.
