Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
need advice on studding bb mains
Old Jun 1, 2011 | 05:56 AM
botlfed's Avatar
Default need advice on studding bb mains
I have a 468 it was rebuilt when I bought it im wondering if I should have my engine guy throw in a set of main studs without line honeing what you guys think
Old Jun 1, 2011 | 06:03 AM
Sublime Dak's Avatar
Always line hone when using main studs.
Old Jun 1, 2011 | 06:56 AM
botlfed's Avatar
That sucks would have to rebuild then would it really be worth the 500 im only going to be spinning 6500 and like 600 horse
Old Jun 1, 2011 | 07:00 AM
mm8ls1's Avatar
I'm was running bolts in a superstock 427 spinning over 8k. Studs are not needed.
Old Jun 3, 2011 | 04:52 PM
CNC BLOCKS N/E's Avatar
X2 and most OEM blocks you to cut the caps at least .003 to be able to line hone and have the caps clean up every where. That how bad GM mains lines cam be!!
Old Jun 3, 2011 | 04:53 PM
Its also a shorter stroke which makes a differance!
Old Jun 13, 2011 | 02:20 PM
94mustang's Avatar
Studs are not needed. But if they are installed ALWAYS line hone. It will need it.
