old school heads
You can buy a set of upgraded vortecs that can hold .550 lift for $500.00. Thats new springs already in that price. If the OP is into the nostalgia thing then get the fuelie heads, if not I say get the vortecs for the cheapie budget.
OP are you rebuilding the entire engine or just doing heads/cam?
The vortec's will damn near run door to door with the Pro Comps.
As far as a checkbook, I will GLADLY write out a bigger check for an American produced head from my checkbook
, but thats me. You do what you want to do. The Best V8 Stories One Small Block at Time
, but thats me. You do what you want to do.It doesn't matter what they weigh though, the vortec's are cheaper than them and still run door to door with them.
Patriot has to be doing something different to their heads because I have seen a set of Pro Comps do poorly compared to other SBC aluminum heads and Patriots run just a little bit behind the same set of heads.
Any proof that Patriot and Pro Comp use the same casting?
Edit: Patriot is casted overseas and finished here in Alabama. They are basically Alabama Cylinder Head. If you go to Alabama Cylinder Head's site and click on performance it links you to Patriot. Pro Comps on the other hand from what I can tell everything is done overseas.
Still doesn't make one better than the other.
