Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Cost of EFI conversion on BBC?
Old Nov 27, 2011 | 04:49 PM
BirdsSince16's Avatar
Default Cost of EFI conversion on BBC?
I did a quick search/skim and couldn't find anything on the subject, which surprised me. If there is a thread I missed I'd be thrilled for someone to link it.
Anyway. I've been offered a certain amount of money to sell my 2000 WS6, and after all is said and done I'll have around 10k to play with. I currently have a freshly rebuilt 454 out of a 76 chevy pickup, along with its T400 trans.
I was thinking of selling my T/A, buying a Chevelle body, and putting the big block and trans in it.
If I did this, it would likely be driven most days, so I want to put an EFI kit on the motor to save a little on gas. My questions are:
1. How much gas mileage should I expect from an EFI conversion.
2. How much would the conversion kit cost?
Thanks in advance for any help.
Old Nov 27, 2011 | 06:31 PM
Parasoth's Avatar
Megasquirt is very cheap, but must be built on your own.
The major EFI's are in the neighborhood of 2-3k.
If you can, sell your Mark IV and pick up a Mark VI block, then convert to L31/LS1 PCM.
EFI Manifold: $400
EFI TB: $400
Rail kit ~100
24x Camshaft Reluctor Ring $30
24x Cam Sync Dizzy $150
24x Timing Cover with CPS (Crank Position Sensor)$100
CP Sensor: $85
Old Nov 27, 2011 | 07:06 PM
The engine I have is kinda sentimental... I know it's weird, but the truck had been in the family since 76 and I bought it from my grandpa, and it was the first engine I ever rebuilt with my dad and brother. I know it would be more practical to change, but I'd like to keep this one. I'd be leaving it in the truck if the body weren't complete trash.
I found a freshly painted 67 SS clone roller for 7k.
Also, anyone have an idea on gas mileage?
Old Nov 27, 2011 | 09:30 PM
Parasoth's Avatar
Depends on a lot of things, if the 400 isn't sentimental pick up a TH200 4R/4l60E for the overdrive and you could probably see an easy 15-20 MPG in a 3500 pound car. Will depend on the converter you have too.. whats the full combo?
Also, if the Mark VI block isn't an option, look into either Megasquirt or if you don't mind spending the money, FAST EFI and the like. With the older block, the EFI choices are slightly limited.
Those Chevelle's are hot stuff.
Old Nov 27, 2011 | 09:59 PM
The converter will remain small until I get another car to drive most days. I'll eventually go all out, but by that time I won't care so much about mileage. The T400 has given me nothing but trouble, so I'd really be glad to dump it for a 4L60E or the like. Thanks for the info!
Old Nov 28, 2011 | 12:09 AM
Big Al's Avatar
First what are you going to do with the car? Old school TBI would be easy on your engine. port injection is harder but still not rocket science. I have a Mustang with a four barrel intake modified to use Ford/Chevy injectors and an aftermarket controller. Holley and others make all the stuff you need. http://www.holley.com/Index.asp?division=Holleyefi
Al 95 Z28
Old Nov 28, 2011 | 07:00 AM
For now I'll just be driving it to school and the local cruise-in for the most part. It's replacing my 00 WS6 as my most-days driver, so I at least need it to be somewhere close to that in terms of fuel-efficiency. I know it won't be as fast, or as efficient, for now.
Old Nov 28, 2011 | 10:41 AM
Big Al's Avatar
Hate to say this but there is nothing wrong with a Qudrajet carb if you know about them. Good gas mileage, decent performance. Ask yourself how come a late 60's GM barge like an Olds or Buick with a 455 inch engine could get over 19 MPG on the highway and weigh almost 6,000 pounds. They had points, no PCM's no injection, no overdrive, no lock up torque converters and no BS. In 1971 they went straight to sh*t thanks to the EPA.
Al 95 Z28
Aerodynamics are for people who can't build engines.
Enzo Ferrari
Old Nov 28, 2011 | 11:14 AM
The engine is from a 76, and the carb was replaced during the rebuild. I really hate getting into qjets for some reason, so I avoided rebuilding it. I get more pissed off than anything when I start to take them apart. Currently running a Holley 650 because we had one laying around.
Old Nov 28, 2011 | 05:45 PM
Big Al's Avatar
Well at some point you need to figure out what it's going to cost in time and material to go injected. Is there a chance there is a stock 454 setup that will work for you? That would be the easiest way.
If I had to do it without a stock set up I'd find a way to get an intake with injectors and a throttle body and start finding options how to control it. The Ford set up used in 88 to early 90's Mustangs work on about anything and there is tons of aftermarket support for them. As mentioned before MegaSquirt, Electromotive, Fast, Holley and lots more are making systems....
Al 95 Z28
Old Dec 5, 2011 | 10:05 PM
RacnJsn95's Avatar
I'm a little late on this one, but on the electrical side, you can get most of what you need for the Megasquirt in a kit. They offer a Carb to EFI kit with a lot of what you need (Megasquirt efi controller, wiring harness stuff, sensors, etc) for $590 (unassembled, build it yourself) or you can also get it assembled for $710... Then you have to track down the engine parts (intake, throttle body, etc) though... I'm currently working on putting Megasquirt on my 72 Chevelle on a 355 sbc. I just finished assembling my Megasquirt myself the other day. I really think it's the way to go if you're on a budget and want an advanced efi setup.
